Old 01-18-2019, 03:04 AM   #1
SavageC20
SavageC20's Avatar
TH400 Kickdown Wire Question
I am in the process of resealing my TH400. When I pulled the kickdown solenoid wires off of the solenoid to remove it and change the o-ring I noticed that the insulation on the two wires was cracked.
Is this going to cause problems or can I just leave it?
(correct me if I'm wrong on the terminology of this "kickdown solenoid")
SavageC20 is offline   Reply With Quote
Old 01-18-2019, 07:51 AM   #2
clay68c10
clay68c10's Avatar
Re: TH400 Kickdown Wire Question
ATF isn’t conductive, so just keep the wires away from the metal. There’s probably a replacement available, but that’s what I did when I bebuilt the 400 in the Cadillac.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 01-18-2019, 01:08 PM   #3
SavageC20
SavageC20's Avatar
Sounds good, thanks.
