Old 01-07-2018, 12:19 AM   #1
mehoff400
trac bar issues
put new lowering springs on my 66 c10 and now i seem to have a little bit of clearance issues. what is the solution to this? i dont have any welding skills
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 01-07-2018, 01:26 AM   #2
Captainfab
60-66 Nut
Re: trac bar issues
Looks like you have a '60-'62 Eaton HO32/33 under your truck. You're going to have to cut that panhard bar mount off of the passenger side axle tube and install an aftermarket panhard bar that bolts to the passenger side trailing arm under the differential.
Old 01-07-2018, 10:14 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
Re: trac bar issues
Yes, you'll need to cut off the rearend housing bracket and switch to a track bar similar to this one:
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-07-2018, 12:56 PM   #4
mehoff400
Re: trac bar issues
Thanks guys, any suggestions on where to get one? i see CPP makes one
My truck
Old 01-07-2018, 01:10 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: trac bar issues
CPP I know they work on a 66. The 65/66 drivers side chassis mount is better than previous years clearance wise I think. I have a 64 and changed to a 65/66 to clear the differential cover. Something to think of (or plan), Once you buy one company's suspension products another company's various other parts "may" not work together. So plan for the future.
https://www.performanceonline.com/19...-Bar-Trac-Bar/
