08-04-2010, 04:45 PM | #101 |
6>8 Plugless........
Re: 84 Crew Cab Rebuild
Nice progress, and good score on some parts.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
08-04-2010, 04:46 PM | #102 | |
Conversion Truck Addicted
Thanks Diesel
Thomas Quote:
08-08-2010, 03:22 PM | #103 | |
A little update
got alot of body work done on the left side but still has some sanding to do repaired the Right Cab corner and inner. Repaired the only rust in the right rocker panels still have some welding and grinding to do but its getting there just primed it for now. also got some it almost welded up at the roof part but for more at the front door sadly
Thomas Quote:
08-26-2010, 01:40 PM | #104 | |
little update
got alot of parts the last few weeks my order from LMC has arived headlights halogen sadly seal beam wanted with bulbs oh well they where only 9 dollers a piece. tail gate lights, hood release cabel, lower coolent hose, headlight addjuster screws 8pc, door locks and a new left side marker old was damaged, the 4 point mirror i ordered and thought it was a set but was only one lol nice quality stain less steel expet the mirrior part it self needs mods to fit what can you expect from universal mirror for 29 bucks lol just got order the second one now. got all 4 brake shoes reshoed cheap and roters turned repacked the bearings in tge hubs and new seals (timkin). got new O-rings for Oil coolers pipes/hoses and hydroboost hoses 15 in total also scored these remote control tire presure and heat sensors from old rims we where cleaning out the atic at work also got the display just forgot it at work. think this is a great little detail pics of my seats got to get them sent out for a rebuild just looking for the right shop with the right price also want heat build into them theres nothing better in the winter time What is the wire for ????
Thomas Quote:
08-27-2010, 02:47 PM | #105 | |
i have taken a decision as i have run aground here on body work and havent gotten anything done the last couple of weeks lack of motivation.
im going to talk to a person i know that does body work give me a price on repair the rest of rust on it make it ready for bondo, primer etc
Thomas Quote:
08-27-2010, 02:51 PM | #106 | |
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
08-27-2010, 02:53 PM | #107 | |
have the repair the dually fenders and repair a big dent in the tail gate
other then that it just sand it down little bondo and prime it nothing major but its the rust in the cab that just draining me from motivation
Thomas Quote:
08-29-2010, 06:08 PM | #108 |
Holy crap you have done a lot! Looks good man! I used to work in a body shop about 13 years ago, had to pay off some welding work on a 350 S-10 swap I did. I can definitely relate to you on how drained you feel.
08-31-2010, 11:30 AM | #109 | |
thanks im not a good welder, i can weld so it can hold but thats it i cant weld nice to be good at body work
Thomas Quote:
08-31-2010, 04:05 PM | #110 |
I know what you mean about welding, that is why I had to pay off the work that was done. I am trying to get a little more welding under my belt, and I think this truck is going to be the thing to let me accomplish that. Keep it up and it will payoff.
09-01-2010, 02:30 PM | #111 | |
little update
got my oil cooler lines mounted had to bend the to long once to clear my electric fans came out good with new o-rings i think the white/gray battery trays fits great a colour change in the engine bay red engine black fenders and white/gray add-ons these are they 4 point towing mirros from LMC they fit horrorbel but got them to work and for the price i dont complain had to mod them abit to get them to fit good btw they are stainless steel had to bend them here in a vise got my rear end all together again with new material on the brake shoes, turned drums and new wheel cylinders there was nothing wrong with the old once but they where cheap so i might as well do it now
Thomas Quote:
09-01-2010, 03:13 PM | #112 |
nice update didnt you just paint that rear end?
09-01-2010, 03:48 PM | #113 | |
i had the cover off to drain the old oil and take a look at how the gears looked like and hoped to find a locker or posi
i though i might as well clean the cover up and paint it diffrent then rest of the axle.
Thomas Quote:
09-04-2010, 11:07 AM | #114 | |
Just got home with some parts
a Powersteering pump a New type Master Cylinder sadly dosent fit hydroboost models Dually hub cab i was missing one the roof part i need to finsish the cab this is from a 83 suburban that had rear end damage. and the plastic throttle support i was missing. also bought a rust free hood and Passenger rear door, blue tinted bug shield and a big ass Grill gard that with push pads will get pics when i pic it all up
Thomas Quote:
09-11-2010, 08:24 AM | #115 | |
Little Update
got my Patch panel weled in and started body work now it is officaly RUST FREE redneck ingenuity this master cylinder looks 10 times better then the old ugly metal canister and also give it the newer look i like im thinking of getting it the master cylinder case turned down abit and the bore in the hydroboost lagre other then that its good my old mastercylinder was toast i had to use over 290 PSI to get the secound piston out
Thomas Quote:
09-21-2010, 12:34 PM | #116 | |
waiting on some parts to arive from US but body work is almost done started to pull some wires thruh the firewall
Thomas Quote:
09-21-2010, 03:17 PM | #117 |
i probably have a better dually hubcap laying around...which one did you need?? just the rear?
09-21-2010, 04:01 PM | #118 |
Robert Olson Transport
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
09-25-2010, 01:15 PM | #119 | |
Pushed her out side to do some shop cleaning and clean her abit
mounted the front clip also Painted my washer fluid bottle its was getting quite ugly looks good with my 2 eletrical fans Here she it inside the shop going to mount the wiring harness and going to fire it up she has been asleep since 10-2-09
Thomas Quote:
09-25-2010, 01:23 PM | #120 |
shweet Do you have a bed for it already?
09-25-2010, 01:31 PM | #121 | |
oh yes its at a friends place just wating with some peices of the old cab i still need to haul off
it just dosent fit in the shop if its mounted well the truck dosent fit in the shop really its a really tight scwese
Thomas Quote:
09-25-2010, 05:47 PM | #122 | |
11-30-2010, 09:37 PM | #123 |
Hey so whats up with this build?
1978 Chevy C10 Bonanza, 405hp/440tq 383, tweeked Th350. http://www.facebook.com/#/profile.ph...&id=1116781152 |
12-01-2010, 02:53 PM | #124 | |
havent been at the shop and work on for a month didnt really want to work on it for some time i have been at it for over a year now, i got a new dayli driver so i can take a breake on this to make it right and proberly redo some shortcuts i did and do it like i really want it.
2WD to 4WD conversion might be comming in the near future Dana 70 Front axle and Dana 80HD from a dodge ram dually, why not go bigger lol also maby a engine tweak..
Thomas Quote:
12-01-2010, 03:16 PM | #125 |
Man, I know it sucks sometimes but don't stop now. You've already got way too much money and time in it. Atleast get it drivable. Honestly, I couldn't have come close to doing what you have done so far. I never could do wires. Just looking at that harness would have been the end of it. I'd turn it into a BBQ pit! lol
