Old 01-04-2019, 03:10 PM   #1
demian5
demian5's Avatar
Correct Gas Cap? Too much pressure!
Ok so I looked and searched on here and found nothing definitive.
Stant site shows:
1970 and earlier 10491
1971 10582
1972 10572
I have a 1970
I don't have any vents on my tank and I get crazy pressure and the cab stinks of gas. The back side of my cap has a vent system but its plastic and I cant pull it apart to cut the spring.
Help? Suggestions? Knowledge you would like to share?
The old one just leaked down my cab and bed when cornering.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 01-04-2019, 03:21 PM   #2
Bob B.
Re: Correct Gas Cap? Too much pressure!
Stant site shows:
1971 10582
1972 10572
I have a 1970
Do you have the correct 1970 gas tank? If it does not have the vent line on top you might have a 1969 tank, or one for a 1970 without EEC. If that is the case you might want to try a 1969 cap. A truck with EEC will have the extra vent line on top of the tank and the charcoal canister under the hood.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is online now   Reply With Quote
Old 01-04-2019, 03:50 PM   #3
FRCvette
I had this same problem with my 70. I ended up drilling a very small hole in the backside of the cap. No more pressure or smell.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 01-04-2019, 04:21 PM   #4
demian5
demian5's Avatar
Well the 69 cap is the same as the 70...
I have no vent lines on the tank except the fuel line for the sender.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 01-04-2019, 05:06 PM   #5
Fbks_Cruiser
Fbks_Cruiser's Avatar
Do you still have the original cap? Like mine, it probably leaked because the rubber seal is old, dry and cracked. Try carefully removing the rubber seal from the new cap and putting it on the old cap.
But be warned, I had gotten a new vented cap from Stant a couple of years ago. The rubber only lasted about 1-1/2 years. Then it started to crack and leak. I guess there are different rubber compounds now a days. I cut a new seal out of some rubber I had lying around. We’ll see how long it lasts.
1972 GMC K2500 Super Custom
Matt
Fbks_Cruiser is online now   Reply With Quote
Old 01-04-2019, 05:10 PM   #6
demian5
demian5's Avatar
My understanding is the caps need to be replaced every couple of years cause of that. No big deal, I just want the right one on my truck so it works properly.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 01-04-2019, 05:48 PM   #7
jeffahart
jeffahart's Avatar
I am running a stant 10623 and it vents. I bought a couple others that did not. When you get the cap blow on the vent, it should vent.
j
White K20
jeffahart is offline   Reply With Quote
Old 01-05-2019, 01:17 AM   #8
rechinca
rechinca's Avatar
FRC is it possible to post a pic of the hole you drilled for reference on the cap?
1971 Custom/10 - 350/3 speed, Orange/White roof
rechinca is offline   Reply With Quote
Old 01-05-2019, 10:27 AM   #9
Shinysideup
Shinysideup's Avatar
Whats too much pressure you speak of? It should hold a little, which I assume you hear when you remove the cap. You may be trying to solve a non-issue.
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 01-05-2019, 02:14 PM   #10
54blackhornet
54blackhornet's Avatar
I learned that NAPA caps are junk ! Bought two and the rubber dissolved in no time at all. Also learned that if you have trouble with your carb losing prime, have to pump the gas repeatedly before starting, you are probably using the wrong style gas cap....
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 01-11-2019, 01:31 PM   #11
demian5
demian5's Avatar
It wants to blow the cap out of my hand and the cab smells like gas bad cause the pressure is trying to come out of wherever.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 01-11-2019, 01:39 PM   #12
demian5
demian5's Avatar
Ok, so I bought one for my truck. A 1970 and earlier 10491.
I blew through the back of it, pressure was released (unlike the 10582 I have that i can't blow through since the tank is supposed to have a vent on this model year). I think "awesome, solved!"
Put it on, make some on ramp maneuvers, gas all over side of truck.
Seems to seal, the lock mechanism is a little lazy compared to the old one... lets return it and try another one.
Replacement cap, same thing. Gas all over. Lock mechanism lazy on this one too.
Back to the cap I've had that builds up too much pressure.
I would like to see what the "hole' thing is about for the current cap. Or maybe I try a 72 cap, but that would be the same as the 71 I assume. Maybe I try and pull the pressure mechanisms out of both caps and swap them...
Ill keep trying stuff till I fix it. However, I know this has been solved by somebody.
The funniest thing I have learned about this (don't tell ANYONE) the keys interchange and work between all of the caps. Buy a cap and open your buddies gas cap...
1986 C20 Scottsdale
Instagram: C10sofOC
Old 01-11-2019, 01:41 PM   #13
demian5
demian5's Avatar
Pictures of this or you are telling tall tails...
1986 C20 Scottsdale
Instagram: C10sofOC
Old 01-11-2019, 01:42 PM   #14
demian5
demian5's Avatar
Want a locking one. Thanks through!
1986 C20 Scottsdale
Instagram: C10sofOC
Old 01-11-2019, 03:12 PM   #15
jcwren
This issue with replacing gas caps every couple years, or declaring the NAPA ones are junk, is most likely because of gas with a high ethanol content. That garbage just DESTROYS rubber.
This idiotic idea of ethanol-based fuels has done far more economic damage than any environmental benefit it purportedly has. It's destroyed rubber in innumerable vehicles and small gas engines, absorbs water far quicker, turns to varnish sooner, and raised the price of corn to feed animals. Just another "good idea" from the government.
1970 C10 LWB Stepside
1971 Dodge Dart
1993 Buick Roadmaster Estate Wagon
jcwren is offline   Reply With Quote
Old 01-11-2019, 08:12 PM   #16
54blackhornet
My statement that NAPA caps are junk is correct ! The store manager agreed wholeheartedly. I also never have put anything other than NON ETHANOL premium in my two 67/72’s, and I mean ever. Both have their original engine and carbs. After pumping numerous times they both start on old style divorced chokes and run perfectly. Not being able to buy something as simple as a proper gas cap is just ridiculous. Hopefully I’ll live long enough to see the return of proper America made craftsmanship once again. And as far as rubber goes, I’ve bought gas filler rubber grommets that failed in less then two years. Never once spilled gas on them either. Same goes for brake and clutch pedal rubber, failure! Same with replacement rubber floor mats.
71 C-20
07 Magnum RT AWD
Old 01-12-2019, 10:37 AM   #17
FRCvette
pictures of this or you are telling tall tails...
2004 SSR
2013 Silverado swb
Old 01-12-2019, 06:03 PM   #18
697498chevy
Car Quest #10623 works well on my 1969 also .
697498chevy is offline   Reply With Quote
Old 02-07-2019, 04:54 PM   #19
demian5
demian5's Avatar
And it DOES NOT leak all over the side of the truck when cornering right?
1986 C20 Scottsdale
Instagram: C10sofOC
Old 02-07-2019, 05:17 PM   #20
jeffahart
jeffahart's Avatar
I had or have a locking one too. I will check my parts this weekend. If I still have it I will get a number off it.
j
White K20
Old 02-07-2019, 05:41 PM   #21
Bigdav160
Bigdav160's Avatar
I don't think you can buy a truly vented cap anymore. EPA mandated that they must hold some pressure.
I am pretty sure I read that replacement caps designed for vented applications hold 1-3 psi
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-08-2019, 03:38 PM   #22
697498chevy
The #10623 cap doesn't leak on right turns on my 69 truck . If I fill it up to the neck and park it in the sun it'll build up pressure and probably leak . I don't fill it all the way up . My truck does have a LMC tank with the vent line plugged . Hope this helps .
Old 02-08-2019, 04:37 PM   #23
Sheepdip
Sheepdip's Avatar
I did the same thing FRCvette did and I have yet to spill a drop on the outside of the cab and my fuel smell in the cab went away.
Sheepdip is offline   Reply With Quote
Old 02-10-2019, 09:52 PM   #24
El Dorado Jim
I have done this on different vehicles and it works
El Dorado Jim is offline   Reply With Quote
Old 02-11-2019, 08:49 PM   #25
jeffahart
jeffahart's Avatar
My 10623 cap vents and breaths. Maybe I got a defective cap. But it does not have the same internals of other caps I've tried. I just might look at one next time I'm at O'Reilly and see if it vents. Anyhow, I finally have I cap I love. I hated the tank bloat.
j
White K20
