Old 02-02-2011, 11:11 AM   #1
CEE1NG_RED
Replacement engine oil dipstick tube...
Where do you guys get your engine oil dipstick tube from that's similar/equal to the quality of the OEM? My 67 came with a 78 c/10 motor/trans (so the previous owner says), but the dipstick tube got detached when I drove it home. The tube resembles this: (http://www.classicchevy.com/chevy-up...1956-1980.html), but I am not sure if this is a quality product. Anyways, how do you guys attach it?? Mine seems to be intact; previous owner put RTV sealant to attach it, but didn't work. Any feedback would be appreciated. I haven't drove it since that incident...
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
CEE1NG_RED is offline   Reply With Quote
Old 02-02-2011, 11:26 AM   #2
truckdude239
truckdude239's Avatar
Re: Replacement engine oil dipstick tube...
Umm i've used the mr gasket it one and stock and i can;t get mine to stay in either i've tried the rtv trick but it seems the hole is to big and the tube to small. So i am goign to wat6ch this and see what every one says
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-02-2011, 11:29 AM   #3
CEE1NG_RED
SO...you havent driven the truck also. Mine spilled a quart of oil out while driving it home; didn't notice it was the engine oil dipstick tube that got popped out of the block. Good thing it didn't mess up my engine!!!
Old 02-02-2011, 02:08 PM   #4
truckdude239
Well i've drove mine with it loose but i dont drive it much i'm interested in the fix for this also
David fuller
2000 Tahoe 5.3l 378
Old 02-02-2011, 07:27 PM   #5
CEE1NG_RED
So...yours leak as well when driving??? Mine does.
Old 02-03-2011, 12:14 AM   #6
Captainfab
60-66 Nut
Have you checked with your local GM dealer parts department? You should get the dipstick itself to go with the correct tube. The tube should be a semi-tight fit that will require some gentle tapping with a hammer to install into the block. As a general rule any of the aftermarket chromed parts are just made in China crap that doesn't fit right.
Old 02-03-2011, 05:57 PM   #7
Lee H
Lee H's Avatar
+++ Get the real thing and make sure the stick and upper tube are a match.
Also if it leaks that much I'd be willing to bet the lower tube is missing.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-03-2011, 07:37 PM   #8
CEE1NG_RED
There's a lower tube?? How do I check if it's in the engine?? I've never done this before...
Old 02-03-2011, 11:18 PM   #9
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Gee I just have 1 big tube. No lower.
Mine leaks too.
John
1999 Toyota Tacoma 4x4
Old 02-04-2011, 01:46 AM   #10
LANDC
LANDC's Avatar
I purchased a new dipstick from GM performance parts and they use an o-ring at the base where it goes into the pan. I made sure the o-ring was greased up before I inserted it into the pan. ( Insert crude comment here) And if I remember correctly I used a little RTV above that to assure no water makes it in.
Custom Vehicle, Custom Problems.
LANDC is offline   Reply With Quote
Old 02-04-2011, 02:25 AM   #11
CEE1NG_RED
What's the part#?? Cost? Pics? Is it made for 67-85 Chevy 350 short blocks?
Old 02-04-2011, 05:52 AM   #12
cdowns
cdowns's Avatar
the GM dipstick is good the only other one i will use for a custom look is lokar it fits great no issues
Old 02-08-2011, 02:31 AM   #13
LANDC
LANDC's Avatar
The dipstick I bought was for my bbc 454. But GM Performance Parts should have any dipstick produced for all sbc and bbc blocks. Grab a catalogue and check it out. They may even have an online catalogue. I identified my oil pan and from there found the appropriate dipstick and tube. Wasn't cheap, but piece of mind when it comes engine componentry is priceless.
Old 02-08-2011, 03:09 AM   #14
CEE1NG_RED
Well..I id. the engine block, but how do you id. an oil pan???
Old 02-08-2011, 05:16 PM   #15
LANDC
LANDC's Avatar
By pictures in the Performance Parts Catalogue I visually identified what pan I have. There were many options for my block, and even when I told the GM parts guy what I wanted he was surprised that pan came with my block. So I confirmed the pan and told him the dipstick and tube I wanted. He in turn confirmed that those were the right parts for the pan I had and voila I have a dipstick and tube. And never again will I forget to take them off before hoisting my engine out.
Old 02-08-2011, 06:18 PM   #16
Lee H
Lee H's Avatar
You really only need to match upper tube and dip stick as a set. Example would be 1972 C10 or 1986 Camaro, it doesn't matter which. The only real difference is the length of the tube and dip stick, long or short. Pretty sure you can call GMC Paul and he'll help. That comb will assure the stick is the right distant below the crank throws. Just add oil to right level on the dip stick. Will probably be 4.5 or 5 quarts for an GM pan or who knows for an after market pan.
Old 02-08-2011, 07:42 PM   #17
CEE1NG_RED
...will the oilpan have a serial# or some ID?? I know it looks like an aftermarket, unless the OEM are chrome plated??
Old 02-09-2011, 08:07 PM   #18
CEE1NG_RED
Just found out that my dipstick is "Made in China." Does your OEM one says USA?? Many Chevrolet dealership parts stores have discontinued the upper tube and dipstick, only found one location, but it's a drive!!!
Old 05-23-2011, 03:41 PM   #19
doodah man
doodah man's Avatar
CEE1NG Red, Did you ever find a source for a good replacement? I ordered one from LMC, but haven't tried it. I guess it's the one that everyone is saying will not fit.
Searched GM performance and GM parts direct but didn't find anything yet.
Still got to get the old piece out of the block first...
1972 C-10 Deluxe
350 V8 - 350TH
We're not the jet set
We're the old Chevrolet set
doodah man is offline   Reply With Quote
Old 05-23-2011, 07:15 PM   #20
CEE1NG_RED
...haven't installed mines yet due to my busy schedule. I ended up buying a GM dipstick tube @ Chevrolet and a Lokar one. I think I'm going to be using the Lokar,
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Old 11-30-2015, 05:51 PM   #21
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I've been going around plugging up oil leaks.
Testing my fixes, I revved the engine up pretty high and held it there. My leaks I worked on are good, but now I'm seeing oil blowing out around the dipstick tube.
Searched and found this thread.
Mine appears to be one of those cheap chrome loose fitting kind mentioned above.
Time to order a good dipstick.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 11-30-2015, 08:16 PM   #22
LostMy65
LostMy65's Avatar
Do you know if the Lokar ED-5002 will work with ramshorn manifold?
Old 12-01-2015, 12:03 AM   #23
68gmsee
Active Member
68gmsee's Avatar
When mine broke a few years ago, I bought one of those chrome ones from local Autozone. I can't remember the brand but had no problem with the fit.
To install it I used a small box end wrench that just fig around the tube but not around the base. I then tapped on the wrench to drive it into the block. It was slightly touching the rams horn manifolds but I was able to bend the tube just enough to give me some clearance.
To determine the accuracy of the dipstick, I changed the oil and filled it up with the required amount. The dipstick was off about a quart so I just scribed it with a file for the "full" mark.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 12-01-2015, 02:03 AM   #24
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Once I make sure upper tube and dip stick length is correct, I use JB Weld to glue and seal the tubes in place. No leaks and no loose dip stick tubes...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
