09-09-2014, 10:04 AM | #1 |
Suppose to be workin........
68 vs 72 steering column
OK guys, got a question for you. I picked up a '72 ( I think) steering column from Randy a while back, and am finally getting ready to clean up and put in my '68. So, as I was pulling the one out of the 68, I notice it is a single long shaft design, and the new one is a 2 piece (I only have the upper piece too ).
I bought the newer column for the three speed stops and my shift collar where the lever mounts was broke. Could not move the tube back and forth to get past the stops. What was the last year for the 1 piece shaft? I am pretty sure the lower bearing is different according to LMC catalog, so maybe that is the breakoff for the design change? So, is the 2 piece a better design in anyone's opinion? Do I need to find the lower shaft, or do I just take what is needed from the newer column and place into the older column and use the long shaft? Thanks for the help
Brent '68 C10 '70 C10 '72 LeMans "03 Trailblazer "Stupidity is like a skill, some are born with it and some develop it over a period of time."" Author unknown |
09-09-2014, 12:10 PM | #2 |
Re: 68 vs 72 steering column
Can you post pics of both so we can see what you are talking about?
09-09-2014, 12:30 PM | #3 |
Yes, but it will have to be this evening when I get home from work.
09-09-2014, 01:25 PM | #4 | |||
Project Junkie! Fishing Poor!!
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
09-09-2014, 03:34 PM | #5 |
I don't know about that, doesn't the 2 piece collapse to prevent the shaft from poking you in a head on collision?
1968 LWB C20 / AC / Wood Bed |
09-09-2014, 11:23 PM | #6 | |
Here are a couple pictures to show the difference in the shafts.
[IMG]IMAG1065 by ksucatz, on Flickr[/IMG] [IMG]IMAG1066 by ksucatz, on Flickr[/IMG] Quote:
[IMG]IMAG1067 by ksucatz, on Flickr[/IMG] Thanks Wes for confirming what I was assuming. So, I guess I either need to get a lower shaft for the newer column, or put the old long shaft into the new column if it will fit.
09-10-2014, 12:17 PM | #7 | |
07-12-2018, 10:31 AM | #8 |
im bringing this back up because i have a column out of a 69 C50 grain truck and it is one piece and does not collapse it is all round bar solid no pins or slip like either shaft in the pics. it is super long overall length, i have a interm. shaft from rag joint to column end from a '72 and i put it next to this 67 68 style grain truck column and it ends right about where a normal pickup burb etc column would if it were using an interm shaft. so can i use this grain truck column with my bone stock manual everything C30 build? its super nice totaly original stock untouched and its 67 68 style everything i want need. i hope its right length! and the underdash mount for ti is a really basic stamped steel U-bracket with two long bolts and big rubber donut around it.. forgot if thats right for 67 68 too or not? its been a while for me..
1965 C30 dually rolling chassis getting built with a '67/'68 body, am collecting parts for body and inside cab and 250/292 engine brackets pieces right now 2018! anything in central IL |
