10-28-2014, 01:16 PM | #26 |
Re: 1960-62 Front Suspension Upgrade
Great post! Awesome documentation! I'm in the process of doing the very same upgrade to the front of my 62, as well as an swapping the rear diff out for a 12 bolt. Looking forward to getting this done by springtime.
05-30-2015, 10:33 PM | #27 |
I'm replacing my front suspension on my 61 with an 83 front clip, can someone show me where the bolts on the 83 are to drop the front suspension. Also I need to change out the rear axel and I'd prefer to use the axel from the 83, would that work on my 61.
Thanks Posted via Mobile Device |
05-31-2015, 01:30 AM | #28 | |
There are 5 bolts on each side of the crossmember that are used to attach the crossmember to the frame. The bolts are located behind the engine mounting brackets. Sorry I can't send you pics to show you. I'm away and don't have pics on my phone. Yes you can use the rear diff from an 83 C10. The 83 rear end is approx 1 1/2" longer then one used on the 60-62 trucks. You will have remove the axle perches from the 83 rear diff and weld new ones back on. I used perches made by captainfab on this forum to replace mine, and highly recommend them. Some things to consider when changing to the wider diff are you planning to lower the truck, what type of wheel and size tire are you wanting to put one the back. Posted via Mobile Device |
05-31-2015, 02:00 AM | #29 |
For anyone in the WA area, looks like you could get this front suspension for $50. I'm not ready for that endeavor.
http://seattle.craigslist.org/sno/cto/5039802354.html
1965 C10 Longbed Stepside 1969 Chevelle Malibu 1962 C20 Fleetside - Build Thread (Sold before I could finish) |
05-31-2015, 10:46 AM | #30 | |
05-31-2015, 11:54 AM | #31 | |
05-31-2015, 07:09 PM | #32 | |
05-31-2015, 08:25 PM | #33 |
07-05-2015, 09:34 PM | #34 |
Nice How to...
I've just installed the crossmember from an 84 C10 to my 66. I used everything from the 84. The idler arm is way different from my 66. What's the best way to install it? I was just going to mount the steering gear and then drill/mount the idler arm last with eyeball checks... ha sounds kinda ify. |
07-05-2015, 10:54 PM | #35 |
There's 2 ways to (or more) to do that.. I just finished doing my 87 doner to my 66.
Some use a fixed point thats the same on both frames and make a template of the doner frame then copy and drill to the 66 frame. The way I did it was connect to the gearbox first and install the main drag link to the idler arm/dead link.. Align the main drag link so its the same distance from the crossmember both horizontal and vertical .. A good way is to use a long straight edge as a shim or spacer until you have the correct angle.. I used my construction laser beam. Once you have the correct angles C-Clamp the dead arm to the frame and mark the drill points |
07-07-2015, 03:14 AM | #36 |
When I took the suspension off of my 83 donor I forgot to take a template of the holes. How difficult would it be to install it without that template.
Thanks! Posted via Mobile Device |
09-08-2015, 04:55 AM | #37 |
great thread!
09-08-2015, 05:41 PM | #38 |
Just a thought.
I'm sure that I am not the only person who likes the torsion bar suspension so I hope some of the guys who are taking theirs out will save the torsion bars and adjusters as a source of spare parts for us. |
09-08-2015, 06:31 PM | #39 | |
ron |
09-08-2015, 07:34 PM | #40 |
I kept the lower Control arms with torsion bars still attached for that very reason.
'62 C10 LWB fleet side. 283 w/ a T5 |
04-17-2016, 02:06 PM | #41 | |
11-11-2018, 12:32 PM | #42 |
11-12-2018, 12:37 AM | #43 |
60-66 Nut
That is a '67-'87 style of idler arm. Member YatYas who originally posted that says his is from his '84 donor truck
11-12-2018, 03:34 PM | #44 |
Thanks capt. I did see where he said that,but napa keeps showing my 61' style
11-12-2018, 07:31 PM | #45 |
AH HA.. I need the piece that is bolted to the frame,thought it was part of idler arm.
11-23-2018, 11:38 AM | #46 |
Junior Member
So this may seems like a silly question, but what is the easiest method for separating all the steering linkages for cleaning/painting? I have a 78 front suspension I plan to swap onto my 62 long bed LS conversion, and I'd like to clean up and paint the steering linkage. The cross member is done, I just haven't figured out how to get all the steering linkages apart. Any ideas? Is a puller required to get the link off the steering box?
11-23-2018, 11:45 AM | #47 |
Penitrant like the new wd40, pb blaster, kroil. And a Pickle fork and 2- 4lb hammer. Puller for box
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
11-23-2018, 01:52 PM | #48 |
But Found Her 25yrs Later!
A lot of autoparts stores will let you borrow many of the tools you'll need.
https://www.autozone.com/landing/pag...ol&mobile=true
11-23-2018, 07:24 PM | #49 |
Junior Member
Thanks Fellas - I think I have most all that stuff, and I have used the local autoparts rentals several times as well ; )
I appreciate the knowledge - Doug |
04-22-2019, 11:24 PM | #50 |
Does anyone still have one of those Idler Arm Brackets lying around??? I seemed to have misplaced mine with having everything powder coated... Otherwise I need to find a way to get that 80's style idler arm bracket to work with my 64 C20 linkage.
