Old 08-30-2003, 08:39 AM   #1
dbenamati
dbenamati's Avatar
Oil pan gasket change help?
Looks like I may have some time today to change the oil pan gasket on my 67 250 6 cyl. I was looking last night at where to put the floor jack on it to make it clear the crossmember, getting it off. Could you jack it at the transmission or Bell housing? Anyone done it lately????
Thanks, Dave
Dave Benamati
Hughesville, PA USA
dbenamati is offline   Reply With Quote
Old 08-30-2003, 10:42 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I think I would try a cherry picker if you have on or I use the harmonic balancer. May not be the best place but it work's..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 08-30-2003, 02:17 PM   #3
68 Stepside
huh?
68 Stepside's Avatar
I second the cherry picker idea (if it's possible). Another recommendation would be to use a felpro 1 piece pan gasket, if they're available for an I6.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 08-30-2003, 05:22 PM   #4
Linus0014
Guest
Posts: n/a
Does anyone have a part # for a 1 piece oil pan gasket for 350?
Old 08-30-2003, 05:27 PM   #5
jef5150
Inline 69
jef5150's Avatar
fel-pro#1885,,,,s/block, double check though,,,jeff http://www.lsr10.com/pdf/lsrwc03p33.pdf
jef5150 is offline   Reply With Quote
Old 08-31-2003, 09:22 PM   #6
dbenamati
dbenamati's Avatar
I got it changed but what a project it was!!!!!
I had Saturday to change it so I went to the parts store and ended up buying the Felpro 4 piece and let me tell you, I'll never do it again without the right equipment. Anyone who had the 67 250, use an engine lift and get the one piece gasket! I did jack it by the pulley (balancer) and had to jack and block and jack again to almost 5 inches to clear the cross member . Actually it was only about an inch for the x member but the oil pump was front and the rest of the distance was to clear that! To make it worse, The gasket front didn't have the front bolt holes in it because GM made that pattern obsolite. Instructions said to just not put in the 4 bolts under the pully. Guess where it is leaking now! I guess I will have to go out tomarrow and drill through the gasket and put those 4 small bolts back in. All in all, it only took me about 8 hours, a gasket and a tube of rtv heat silicone. Could be worse huh? It looks great though my back is killing me!!!
Dave
Dave Benamati
Hughesville, PA USA
Old 09-01-2003, 03:59 AM   #7
COBALT
COBALT's Avatar
This is the 1piece people were talking about for the V8. The part number for this one is FEL-OS34510T. You need the one for the I6. Check out Felpro's site, or another supplier for it:
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
