Old 11-30-2009, 11:08 PM   #1
Bamer36
Bamer36's Avatar
Gauge cluster
I have a 84 GMC 1/2 ton with A/C looking for a website to buy some new ones mine are done
Bamer36 is offline   Reply With Quote
Old 12-01-2009, 09:19 AM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Gauge cluser
Hey Bamer36, glad to have you aboard with us. You will find there is a ton of information on the site and in the heads of so many members its astounding. I'm actually going to move your thread over to the 73-87 Message Board so some of the square body owners will be able to help you locate the correct gauge cluster parts.
Keep you eye open to the 73-87 parts board as great parts owned by members of the board are posted daily, including OEM, NOS, aftermarket, etc. Also check out Classic Parts of America as they have a ton of aftermarket replacement parts which should help you rebuild your cluster.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-01-2009, 10:03 AM   #3
68 TT
Still plays with trucks
68 TT's Avatar
Re: Gauge cluster
What do you mean "mine are done"? Do none of them work, some work, damaged by fire etc...
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-01-2009, 06:14 PM   #4
Bamer36
Bamer36's Avatar
Re: Gauge cluster
they work but when i turn my lights on they die so there grounding out somewhere and they dont light any more so i cant see them at night and there stock
Old 12-01-2009, 06:22 PM   #5
74 C-30
Dually Pride
74 C-30's Avatar
Re: Gauge cluster
that might not be the gauge, could be the circuit board behind the guages
LMC Truck Gauges
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
Old 12-01-2009, 06:35 PM   #6
68 TT
68 TT's Avatar
Re: Gauge cluster
Pull the cluster out and take a look at the circuit board to look for damage and check the condition of the ground & power wires to look for burned areas or corrosion.
If everything looks good pull out your headlight switch and install a new one. I have seen them do some funny stuff.
Old 12-03-2009, 06:39 PM   #7
Bamer36
Bamer36's Avatar
Re: Gauge cluster
Know of a site that has updated gauges so i can up-grade
Old 12-03-2009, 06:49 PM   #8
68 TT
68 TT's Avatar
Re: Gauge cluster
There are all sorts of options for updated gauges. It all depends upon how much money you want to spend.
Used stock gauges that work
retrofit other GM gauges into stock gauge panel
low end aftermarket analog gauges
mid priced aftermarket analog gauges
high end aftermarket analog gauges
aftermarket individual digital gauges
aftermarket drop in digital gauge package
Old 12-04-2009, 08:23 PM   #9
Bamer36
Bamer36's Avatar
Re: Gauge cluster
looking for mid priced aftermarket analog gauges just something nice cause im rebuilding the car as you can see but i dont need any that are for racing and cost $200 for one gauge. as you can see from the pic of my car in my avatar im kind of all show no
