Old 10-05-2010, 09:34 PM   #1
sjarrett71
sjarrett71's Avatar
Is This Legit?
Here is a Craigslist ad I found while looking for a TH400 transmission. Is this original or what?
http://stlouis.craigslist.org/pts/1990023697.html
-Scott-
sjarrett71 is offline   Reply With Quote
Old 10-05-2010, 09:40 PM   #2
Olden Days
Living In The Past
Olden Days's Avatar
Re: Is This Legit?
I would think it is a TH375 except the year dont match his 86. Maybe it was not original to the van
copied from http://www.nastyz28.com/chevy-transm...tification.php
THM375: This transmission is a derivative of the THM400 sharing the external appearance of the 400. It'll be marked 375-THM on the bottom of the tailshaft housing. It's a light duty version of the THM400, has ABSOLUTELY NO RELATION to the THM375B, and was found in 1972 to 1976 full-size cars. The Turbo 375 was modified to accept the Turbo 350 driveshaft yoke.
Olden Days is offline   Reply With Quote
Old 10-05-2010, 09:44 PM   #3
pumpgas
pumpgas's Avatar
Re: Is This Legit?
1 thing I know for a fact and that is a 350th tail shaft will in no way bolt to a 400th main case.
00' Z28 ("wifes" car)
92' Mustang w/sbc everything needs a little heart beat
87' GMC Sierra Classic Short Bed Fleet side almost stock
69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it
pumpgas is offline   Reply With Quote
Old 10-05-2010, 09:50 PM   #4
sjarrett71
sjarrett71's Avatar
Re: Is This Legit?
Can you explain what the trans is then?
-Scott-
Old 10-05-2010, 09:57 PM   #5
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Is This Legit?
i agree this trans here came out of a 86 1/2 ton i had it has a 400 shaped pan but its more like a 350 a half breed if you will
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 10-05-2010, 10:01 PM   #6
sjarrett71
sjarrett71's Avatar
Re: Is This Legit?
Do you think it would be worth buying? I just want to drive my truck, it's no hot rod.
-Scott-
Old 10-06-2010, 02:53 AM   #7
raycow
Re: Is This Legit?
It doesn't really have a TH350 output shaft. It has a modified TH400 output shaft with the same spline size as a TH350.
Ray
raycow is offline   Reply With Quote
Old 10-06-2010, 04:49 AM   #8
rollinhard
rollinhard's Avatar
Re: Is This Legit?
We just took a trany out of a 87 chev 2wd that looks like that and it looks like a th400 with a long output shaft. The guy put a 700r4 in out of a 89 rally van and it bolted in with no driveshaft modifacations and was splined the same. The guy at the trans shop had never seen a 400 with that long of an output before
If you can't impress them with your inteligence, dazzle'm with your stupidity
1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe
rollinhard is offline   Reply With Quote
Old 10-06-2010, 09:09 AM   #9
Olden Days
Living In The Past
Olden Days's Avatar
Re: Is This Legit?
Looks like there is such a thing as TH475 or (3L80HD) Here is a thread http://www.hotrodders.com/forum/gm-t...ans-93088.html where they are discussing it. Maybe will help
Old 10-06-2010, 11:40 AM   #10
rollinhard
rollinhard's Avatar
Re: Is This Legit?
after reading that im a little more confused. It seems like its a 3l80hd but the other guys r saying no its different. The one i have is th400 pan with 27 spline output just as the guy describes
