Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 05-13-2012, 01:25 PM   #1
JCs72C10
82 C10 Neutral Safety/Backup Switch Wiring
I need a little help with wiring this switch.
What I know: there are two purple wires that connect the ignition switch, NSS, and the starter (the two pins on the left). I also know the light green wire sends power to the Reverse Lights.
What I don't know: what the hell the blue wire (in the same connector as the light green) connects to and what the final pin on the NSS connects to...
I've searched and searched... checked multiple diagrams.... I'm stumped....
I'm guessing the blue wire is a power source to the NSS for the Reverse lamps, but I don't have a clue what the other pin goes to or what color wire connects to the NSS pin itself. Any help would be greatly appreciated.
JCs72C10 is offline   Reply With Quote
Old 05-14-2012, 08:47 AM   #2
JCs72C10
Re: 82 C10 Neutral Safety/Backup Switch Wiring
Well, I figured it all out...finally. The blue with does supply power and the other lone pin is for ECM equipped trucks.
I don't know how to delete the thread, or I would.
Old 05-14-2012, 11:14 AM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I saw your thread and looked at several diagrams I have saved and the blue wire does feed the light green on all of them. I finally found one that shows the lone wire going to the computer but I saw that you had already found that out.
You can ask a mod to delete the thread but I would like to see it left up because there are others that might have the same question and you have provided the answer.
This one shows the NSS in the center with the blue wire to green and no purple wires.
77-79%20Body%20Wiring%202[1].pdf
This one is in the lower right and shows all the wires and the lone wire to the ECM. It's an 85 diagram.
Name:  85 fuse box.jpg
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 07-24-2013, 12:13 PM   #4
egaray281
egaray281's Avatar
how do i replace this part? do i need to drop the steering column and were exactly is it? thanks in advance!
egaray281 is offline   Reply With Quote
