Old 08-18-2018, 01:28 PM   #1
ACII
vent window broken handle ?
Hello
unfortunately the stud of the vent window dropped of .. so i cannot mount a handle bar
Do u might know how to fix that problem respectivel where to buy a stud and handle bar ??
Thanks a lot
Achim
ACII is offline   Reply With Quote
Old 08-21-2018, 11:45 AM   #2
gigamanx
Re: vent window broken handle ?
I haven't had any luck finding similar listings for the side vent or the front cowl vent handle. I'm wondering if you'll have to fabricate one based off the broken one.
Edit: Found the cowl vent
https://www.classicindustries.com/pr...rts/14230.html
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 08-21-2018, 11:54 AM   #3
68JOHNDEERE
You may want to find a vent assembly from a donor truck if possible. The studs for the handle are pinned into the glass frame.
The glass can be removed from the glass frame, and weld that stud from the back side, grind down, and reinstall the glass? I had to remove the vent from the truck and disassemble the vent to perform this.
68JOHNDEERE is offline   Reply With Quote
Old 08-21-2018, 08:04 PM   #4
sack54
check out the eBay they had right side replacement .Looked to be Nos.
sack54 is offline   Reply With Quote
