01-18-2019, 09:49 PM | #1 |
Pics of how to route and fasten lines to frame?
I can't figure out the best method of routing the lines and making them pretty. It would be nice if there was a "modular" tubing clamp so that you could set up the clips along the frame rail and choose which size to install in which spot. Leading to the rear I'll have 3/8" air tubing, stainless brake line, fuel supply and return lines, and of course the wires for the rear tail lights. Either I don't know the terminology to search for, or nothing exists (...and I don't believe that would be possible).
It would be nice to see how others have routed their lines to keep everything tidy, secure, and cosmetically pleasing. |
01-18-2019, 10:02 PM | #2 |
Re: Pics of how to route and fasten lines to frame?
I'm planning on using these clamps for all my lines
https://www.amazon.com/Rubber-Cushio...SXEHCXPS08NVHK
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
01-18-2019, 10:04 PM | #3 |
Ford trucks have what you may be looking for. Plastic holders that will retain (I think) 3-4 lines or a harness
01-18-2019, 10:56 PM | #4 | |
Have you decided on the method to fasten those? I don’t want to use screws because I’d have sharp points pok8ng out everywhere. That leaves a bunch of short stainless nuts and bolts. If that’s what’s necessary then that’s what I’ll do but it will require lots of drilling and lots of nut/bolt work. |
01-20-2019, 01:35 AM | #5 |
10 24 machine screws with nyloc nuts all SS. Put some white grease between the rubber and lines to stop rust. Split loom with SS trailer wire clips on the opposite side
Do it, Do it right, Do it right the first time Last edited by Metaldoc; 01-20-2019 at 01:42 AM. |
01-20-2019, 10:45 AM | #6 |
I was planning something just like Metaldoc. Clean, simple, and affordable.
01-20-2019, 11:08 AM | #7 |
Almost Satisfied
These are what I’m using on my build. Very good product. Can get them at Summit
https://www.notchead.com/line-clamps.html
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
01-20-2019, 11:19 AM | #8 |
LMC sells the Notchead fastening system now. I just received an email from them probably yesterday about this specifically.
Regards Steve |
01-20-2019, 02:20 PM | #9 |
Made4You Products makes similar clamps and kits. I've used them in the past with good luck and they're made in the USA. You can order them direct or through Summit.
https://www.made4youproducts.com/chazisclamp
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
01-20-2019, 03:32 PM | #10 |
subd
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
01-20-2019, 08:35 PM | #11 |
I use those same rubber insulated fuel line clamps. I just used one hole and I had one going in each Direction so that you could hold two lines with one bolt.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
01-20-2019, 08:38 PM | #12 |
Here is a better picture of two lines running parallel to each other
01-20-2019, 09:35 PM | #13 |
Should never run fuel and electrical together. If the electrical shorts you got a big fire.
Do it, Do it right, Do it right the first time |
01-21-2019, 10:08 AM | #14 |
Active Member
That's exactly how we secure wire and tubing runs on airplanes.
Previous C10's 69 SB CST - sold 72 Cheyenne Super LB - sold |
01-22-2019, 11:10 AM | #15 | |
01-22-2019, 04:17 PM | #16 |
