04-01-2018, 06:07 PM | #1 |
Bed Cross Sills Uneven
I am mocking up the bed on the 66 and noticed that the tops of the sills are in alignment from front to back except for the rear one. It's about 1/4"-3/8" lower than the front three.
It's been years since I last test fit the bed and I don't remember this issue back then. Am I missing something here? |
04-01-2018, 06:39 PM | #2 |
Re: Bed Cross Sills Uneven
Picture would help
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-01-2018, 08:33 PM | #3 |
Here ya go. With a straight board laying across the front three sills, you can see the gap between the rear of the board and the rear sill.
04-02-2018, 11:10 AM | #4 |
meowMEOWmeowMEOW
Are all your panels and sills from the same truck? When I was redoing my bed in the '66 post accident, I realized my donor front panel and one sill was different. There was a steel floor available in the 70's which doesn't have the thickness of the boards, and the floor sat a bit lower...but otherwise they fit the same.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
04-02-2018, 11:23 AM | #5 |
Were the bed sides assembled? My 66 was off just a little and the back has one 1/8" thick washer under it and I just pulled the boards down the last little bit.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
04-02-2018, 02:14 PM | #6 |
Moderator
I would think that once the entire bed is put together you'd see another problem. I wouldn't fit the wood the way you have it now, things may change dimension wise once its all together.
04-02-2018, 07:30 PM | #7 | |||
A simple shim at both attach points on the rear sill should take care of this but I'd like to why I am having this issue before I do. |
04-02-2018, 07:53 PM | #8 |
Moderator
Until it's all together you really dont know what you have. It's all a guess or shot in the dark. And I'm talkin no light!
