04-08-2018, 12:01 PM | #1 |
1963 Gmc 1500- Do I have an odd duck
So currently I'm laid up after 3rd back surgery here on 6th and so that gives me lots of time to ponder small details of what I want to do with my truck once I'm able to work on it again. I also keep thinking of small things I noticed with my truck that doesnt seem to be the norm and was hoping to get some info. I bought the truck from 2nd owner who had just gotten it so truck was almost a 1 owner truck and as far as I know is not modded in any way.(purists please look away before I start my build) But if it makes you feel better the truck may be near original but needs alot of work (rust,previous repaint,smokes,brakes,no bed floor etc)
1st- 3/4 ton long bed stepside with a dana rear axle not eaton, is this normal? No pics but you know what a dana 60 looks like. 2nd- Giant box under dash that says motorola on it for radio that I havent seen in other's trucks. |
04-08-2018, 12:24 PM | #2 |
Re: 1963 Gmc 1500- Do I have an odd duck
Full side shot?
04-08-2018, 04:14 PM | #3 |
Here is best I have at moment, this is from ad when I bought it.
04-08-2018, 07:03 PM | #4 |
I believe the Dana was stock in GMC’s
That box is probably a two way radio type deal, it certainly isn’t stock
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-08-2018, 08:18 PM | #5 |
ah ok it looked like it was wired into the trucks radio so I didnt know if it was some dealer option or something, maybe its just using the speaker from radio. I will have to try and investigate lol. The truck is kept at my parents place since thats where I can work on stuff so it will probably be week or two before I even get to see it again.
04-09-2018, 12:02 AM | #6 |
60-66 Nut
The '63-'66 GMC 1000's typically came with a Dana 44 and the 1500's typically came with a Dana 60. There is lots of aftermarket support for the Dana 60's.
04-09-2018, 05:16 AM | #7 |
Cool ty all for info, I'm just used to seeing the round eaton under the 3/4T stuff this age more than the 60. I'll actually be replacing whole frame setup and end up with a D60 & D70 combo under it but was curious if it was a common stock setup.
On the radio I will have to poke around under dash once I can bend again, I know the radio worked and I just assumed the blueish motorola box went along with radio since they were wired together. Worlds first prototype car phone? Kidding obviously lol |
04-09-2018, 11:04 AM | #8 |
Dana 44's are possibly the most common differential on the market. Lots of aftermarket support for them.
04-09-2018, 11:40 AM | #9 |
44s, are cute! He is talking big boy toys. The 60/70 combo is what's under my one ton.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
04-09-2018, 06:06 PM | #10 |
04-09-2018, 11:19 PM | #11 | |
Getting quite far off track already with the dana44 stuff that has nothing to do with truck in question but here goes. I really dislike blanket statements like that (especially incorrect info). Might want to rethink the "just about all of them part".....here is 40 years of most common jeeps and just a disclaimer I might be off about some info here so please do your own research. CJ5 - 1978 dana 30/amc 20 CJ7 - dana 30/amc 20 till 86 then was a 30/44 combo (1 year only) YJ - dana 30/dana 35 basically for entire run TJ - dana 30/dana 35 standard with 44 as a rear only option till rubicon which is 44 front and rear 03-06 so 3 years only XJ - dana 30/dana35 or dana 30/chrysler 8.25 except for special order tow package avail in 87-88-89 again 3 years ZJ - dana 30/dana 35 except you guessed a tow package aluminum 44 avail for 3 years 93-94-95 JK - dana 30/dana 35 except for rubicon dana 44's JL - now uses a metric dana axle but very similar to 30/35 combo in size with rubicon having 44 sized replacements. Dana 44 isnt a bad axle but I think you meant 1 out of every 5000 jeeps has the tiny chance of maybe having a dana 44 and many have been broken with 31-33" tires and stock sub 300 horse motors or just from the weight of JKU's bending them. now back to topic at hand I said in first post it was a dana 60,which I wasnt used to seeing and captainfab was just adding in that 1000's have dana 44 & 1500's had dana 60. I have no intention to run this axle like I said but yeah the aftermarket is HUGE for a dana 44 or 60, If I didnt already have the 60/70 setup though it would be getting a 14bolt rear. |
04-10-2018, 12:35 AM | #12 |
60-66 Nut
I personally would like to see you post a build thread on your 4wd conversion once you get healed up and able to work on your truck.
04-10-2018, 05:23 AM | #13 |
Definitely will do one once I'm back together lol. I have thought of starting one numerous times as I was collecting some parts but figured I'd wait till I have most of the stuff and can actually build it while updating thread so it doesnt kinda stall out.
01-29-2019, 11:57 AM | #14 |
So long time without me remembering to update this.
Radio is a Motorola Model 600 radio first released in 1950, not sure how long they were available. |
01-29-2019, 04:48 PM | #15 | |
If the GMC in the original post is a floating axle-type, it's a 60. (I can't tell from the pic). If it's not a floating rear, it's a 44. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
01-29-2019, 05:26 PM | #16 | |
I love all things radio and that old stuff is the coolest. Cool truck to by the way!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1998 chevy c1500 4.3L 5speed (My current driver) 2002 Chevy s10 4.3L auto 4x4 1971 mercury monterey wagon 400 auto To many projects! |
01-29-2019, 07:01 PM | #17 | |
Now I'm really not looking to get into it about jeeps further but here you go. From 1955-1968 the DJ came with dana 27 then from 1969-1984 it had a dana 44. Again I like dana 44's, I'm not saying there was never a dana 44 in gmc trucks, I'm not saying there was never a dana 44 in a jeep. I said it wasnt exactly in every jeep made in past 40 years, its actually rather unusual to find one in a jeep from the factory. I'm just used to seeing a eaton rear under this vintage of 3\4 ton truck so the dana 60 surprised me (thinking about it it might be because I have seen a bunch more 60-63or66 chevy trucks then GMC's) |
01-29-2019, 07:16 PM | #18 |
Thanks man! I looked for a long time for one but they always slipped past as I either didnt have the money or when I did I couldn't find one forsale. Now I got one and haven't been able to work on it due to my knee first then my back but hoping that all changes soon with lucky back surgery #4...
