Old 11-05-2017, 03:58 PM   #1
WyattTX
Bleeding disk/drum combination valve.
I am trying to bleed disk/drum combination/proportion valve, like what is found on the 73-87 trucks. But I notice there are two different tools for the job. One being a a plug that temporarily replaces the warning light, and holds the valve. And the other is a clip like took that holds the front metering valve outward. Which of these works better? Thanks.
WyattTX is offline   Reply With Quote
Old 11-06-2017, 07:20 PM   #2
truckdude239
truckdude239's Avatar
Re: Bleeding disk/drum combination valve.
Ive never had to use one if the vavle is blocking one side what i normally do is say its blocking off the rears i open a front bleeder and slowly push the pedal till the light goes out then the vavle is recentered i then gravity bleed it then pressure bleed once i have fuild at the wheels
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-06-2017, 10:52 PM   #3
WyattTX
Thanks truckdude, I might toy with this some more. Though I think I will go ahead and try to use the the tool I mentioned. I would try your method, but my warning switch wiring is not installed yet, so I dont have much for reference.
