Old 11-15-2018, 09:25 PM   #1
65c10restomod
Question stepside bed
is there supposed to be a notch in this cross sill at red arrow ? It is kicking the step hanger back and bending the front bed panel (note: bed is upside down)
65c10restomod is offline   Reply With Quote
Old 11-16-2018, 08:04 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: stepside bed
Is the front cross sill installed properly? Does it measure as shown in the Mark-K instruction below? The 2-3/8" measurement for this cross sill.
Old 11-16-2018, 04:23 PM   #3
65c10restomod
Re: stepside bed
thank you,
the cross sill was in the wrong place it looks like it doesn't go under the front panel
Old 11-16-2018, 05:10 PM   #4
The Rocknrod
Moderator
Re: stepside bed
Originally Posted by 65c10restomod View Post
thank you,
No it doesn't, it's mounted at the first set of holes behind the front bed panel. You will see a slight gap from the top (if the wood is not installed) between the cross sill and the front bed panel. The wood sits on top of it but under the sides L-shaped brackets that run the length of the bed.
Here I went out and took a pic, the wood I'm using is just there as a spacer until I get the real wood.
Old 11-16-2018, 10:44 PM   #5
65c10restomod
Re: stepside bed
thanks for the pic.
Thread Tools
Display Modes
