12-07-2005, 05:06 PM | #1 |
LT1/LS1 Engine Management
I have an LT1 and 4L60E transmission from a 96 Trans-am WS6 for installation in my 52 Chevy truck. The truck will have all power options/AC/cruise control/etc. The engine/trans will remain stock but I want to clean it up by removing any/all the smog stuff I can. I have the original computer and harness from the TA, but the harness does have some damage from an accident. I would like to get some ideas/advise on how others have dealt with installing the LT1/LS1 into non pollution required vehicles. What pollution control items can I remove and how did you handle the computer/harness as far as re-programmed or replacing the entire engine management system
12-07-2005, 11:17 PM | #2 |
Re: LT1/LS1 Engine Management
I've got the same set up in my 48 (http://67-72chevytrucks.com/vboard/s...d.php?t=179199)
An aftermarket harness is the way to go, it will save you time, money and headaches. Most are very simple to hook up. There are many companies out there: Street and Performance Painless Howell Engineering (this is the one I used, but all are good companies) Ron Francis. Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-11-2005, 08:43 AM | #3 |
I have a 5.3 Vortec and 4l60e tranny in my '56 Burb. I just mailed my harness and PCM to http://www.wait4meperformance.com/ for him to modify the harness as a stand alone and reflash the PCM for $340 includes return shipping. I learned about Jess Bubb owner from another forum that had nothing but high praises about his work. Good luck.
12-12-2005, 12:20 PM | #4 |
do a painless kit...had no problem installing it. it works great.
mike midwest images http://www.myspace.com/midwestpaintandmetal http://www.webshots.com/user/midwestimages http://www.midwest-images.com |
12-12-2005, 03:12 PM | #5 |
Thanks. This is all good information. I hope it keeps going as I like being informed before I make my decision.
I would still like to know what I can get rid of in the smog department. I want to put headers on the truck and based on what I've read I should keep the o2 sensors on the exhaust but can get rid of the rear o2 sensors since I will not run catalytic converts. I am also thinking I can get rid of the air pump, and egr. Like to have your opinions. |
12-14-2005, 04:31 PM | #6 |
www.73-87chevytrucks.com
Might also look into megasquirt. Built it yourself and install.
http://www.megasquirt.info/ ElGracho is using one on his: http://www.gmcspecialeditions.com/ And I am sure you have seen this 10 second pickup he is also using megasquirt: http://www.neufamily.org/truck.html
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
12-15-2005, 10:33 PM | #7 |
Street Rod Dreamin'
Location: Work:Batam, Indonesia/ Home:League City, Texas
Welcome to the board!
1954 Chevy 3100 Panel Truck 2004 GMC Yukon 2007 GMC Sierra 4X4 "I am for doing good to the poor, but I differ in opinion of the means. I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it." Benjamin Franklin, On the Price of Corn and Management of the Poor, November 1776 |
12-18-2005, 08:16 PM | #8 | |
Just Don't Stop!
Just so you know, MegaSquirt will not allow you to control timing on a LS1 motor with coil on cyclinder design. Nor will it allow sequencial fuel injection only batch or bank fire systems. It is great for controlling fuel in a boosted LS1 design when you have gone past the air volume max on the Mass Air Flow meter but it won't allow you to do a lot of the simple stuff that LS1Edit or HPTuners will... Just FYI, Taylor
1968 C10 build in process TT LSA/6L90e/9" |
