11-21-2005, 07:46 PM | #1 |
Help with shackle removal.
I'm installing new leaf springs and shackles and would like to know the best method you have found to remove the threaded pin sleeve from the frame hanging bracket. I also have one on the front that has the threaded pin brocken off in the hanger. I've been scratching my head on this one for awhile. Any sugestions welcomed. Thanks, Erik
12-10-2005, 12:30 AM | #2 |
Clunker Farm, Proprietor
Re: Help with shackle removal.
Well, the way that it's supposed to work is as follows (roughly per factory repair manual):
remove zerk fitting, thread slide-hammer fitting into pin and attach hammer, back pin out with the slide hammer The zerk fitting uses pipe threads -- I think that they're 1/4" but I'm not certain. I don't know if any of the current slide-hammer manufacturers sell the correct fitting. You might have to fabricate the slide-hammer fitting.
Drew Chief Junk Jockey |
12-12-2005, 10:07 AM | #3 |
Thank you for your answer Norselander.
I have found this information myself. I guess my real question is has anyone had a pin sheared off in the hanger that is attached to the frame. The pin broke off on the grease zerk end and the other end is tapered so I have nothing to get a hold of it to remove it. I will try to pound it out with a punch. |
12-12-2005, 09:47 PM | #4 |
I replaced the shackles on my 1949 chevy half ton a few years back.
found a rod smaller than the insert, hammer and a good aim worked for me. Just make sure that the frame is stable on the jack stands and swing away. |
12-15-2005, 07:19 PM | #5 |
I was able to pound mine out with a punch as well.....Its really not the best design in the world but it functional.
Todd |
12-29-2005, 07:37 PM | #6 |
Gave up on pounding out the bushing after several hours of banging.
I have ground off the rivets and am discarding the hanger. Now I am looking for a good frame shackel hanger. If some one has a spare please let me know how much. Thanks |
12-30-2005, 10:32 AM | #7 |
Led Sled! Discs R 4 ME!
Eric, If you can get a drill bit into the rubber bushing, drill out the rubber working your way around and it will pop out. then clean up the shackle and press in a new bushing.
12-30-2005, 04:50 PM | #8 |
I am parting a 58 long bed. Let me know the hanger location you need,
I will see if I can get one off for you. I do charge extra if I bust a knuckle. |
12-30-2005, 06:59 PM | #9 |
This thread has turn to a want to buy thread, Please read below.
Please take the time to read the rules before posting here- XI. All For Sale posts shall have a price or prices, as well as your location. No bids or auctions allowed here!!! If you don't know the price of what you are selling, then you should do some research. If a Moderator or Administrator here asks you to post price(s) and you have not within a 12 hour time frame, they will delete your thread, period. XIV. As of October 15th 2005 subscribing members will be the only ones permitted to post for sale and want to buy ads on any classified section of this site. All other rules of buying and selling still apply. 67-72chevytrucks.com, its administrators or staff are not responsible for any transactions on or off the forums. We will work hard to ensure you a smooth transaction, and help in the event you may need it, but all for sale and trade areas are buyer beware. Any persons who have misrepresented an item, lie about an item, fail to deliver, or are in violation of any of the rules will forfeit there subscription fees and be banned from 67-72chevytrucks.com The Forum staff would like to encourage you to become a subscribing member. Your support will be greatly appreciated. Subscribe below. http://67-72chevytrucks.com/vboard/payments.php Last edited by DennyB; 12-30-2005 at 07:01 PM. |
