Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 09-10-2017, 10:38 AM   #1
Rickysnickers
Motive brake bleeders
Anyone have or use one of these? Just curious if you liked it and it worked for you. https://www.motiveproducts.com/colle...c-bleeder-kits
Old 09-10-2017, 03:40 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Motive brake bleeders
I've seen one used at a local shop...worked great..I have one of the elcheapo ones from O'Reillys...it works ok also..
Old 09-11-2017, 10:31 AM   #3
truckdude239
truckdude239's Avatar
I use a matco brand that uses shop air works great i use it for every thing i use it to suck power steering fluid and stuff
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 09-11-2017, 10:15 PM   #4
nlped
nlped's Avatar
I have one and it's fantastic...& simple! I've had others but they were either messy or junk. This is a good piece. I've used it on all kinds of applications. I've purchased several adapters for different applications, btw.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-12-2017, 03:03 AM   #5
GIZZ
GIZZ's Avatar
I have one too. I only remember to use it when I'm having a problem. Great tool for the money.
GIZZmotorsports on YouTube & my panel truck build
'69 c10 panel, '75 c35 flatdeck car hauler
GIZZ is offline   Reply With Quote
Old 09-12-2017, 08:56 PM   #6
racecougar
racecougar's Avatar
Fair warning: once you buy it, you'll end up buying the attachment for every vehicle you own. It works great.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 09-12-2017, 08:57 PM   #7
nlped
nlped's Avatar
Precisely!!! My wife is so happy that she will never hear, "Pump it up... hold it...".
Carter
Old 09-12-2017, 09:05 PM   #8
Rickysnickers
Thanks fellas.
Old 09-17-2017, 09:50 AM   #9
04ls1gto
I've got one and it makes bleeding brakes a one man job. Only issue I had was getting plate sealed to master but a few clamps fixed that. Well worth the money
04ls1gto is offline   Reply With Quote
Old 05-10-2018, 01:35 PM   #10
pilotXC
Old thread, but my buddy made one from a garden sprayer. I recently was replacing my master cylinder over at his shop and could not get the pedal to come back, he eventually said to use the power bleeder and there was still air in the rear lines, even though it came out with no air when manually bleeding them... They are life savers!
pilotXC is offline   Reply With Quote
Old 05-10-2018, 10:31 PM   #11
Rickysnickers
I bought one, but have had issues with it, which I'm sure are operator error. In the photo above, one of the guys uses clamps on the master cylinder. I tried that and still had brake fluid going all over the place. It was a huge mess. I still think there is air in the lines somewhere too, as my brake pedal goes to the floor, when driving. If I pump it a couple of times, it comes back. If any of you are wondering, no I haven't driven it much at all in this condition.
Old 05-11-2018, 06:03 AM   #12
04ls1gto
I put a very small amount of grease on the mating surface to help seal. Then put two c clamps on it and pump up with just air at first to check for leaks. Once you fix leaks then add fluid and bleed
Old 05-11-2018, 12:04 PM   #13
pilotXC
The one my friend built, he attached a piece of gasket to the plate covering the MC and I used large C clamps like the previous poster did and worked fine. You don't need much pressure to push the fluid through 10 psi is plenty!
Old 08-25-2018, 09:16 AM   #14
dirtyjim
dirtyjim's Avatar
I've got a homemade one that I use the motive attachments on. I used a 1/2 gallon sprayer that I threaded for a gauge. they are nice
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 08-25-2018, 06:38 PM   #15
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
How much pressure do those take to operate?
Steve
1997 Tahoe LT 4D 2WD (DD)
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 08-26-2018, 11:12 AM   #16
Rickysnickers
10psi.
