08-07-2018, 11:01 PM | #1 |
th700 into 292i6
Anyone try this?
I know it bolts on and that i will have to convert into 2 wire in the trans. My question is will I need a spacer for my starter or will i b able to use a v8 starter that will mount on with no problem? |
08-07-2018, 11:18 PM | #2 |
60-66 Nut
Re: th700 into 292i6
The issue will be connecting the TV cable correctly and with the correct geometry so that you don't burn up the trans. If you happen to have a 4bbl on that 292, it will be not too difficult. If you have a stock carb, it will be very difficult.
For a starter you just need the correct one for the size of flexplate you use.
08-08-2018, 02:50 PM | #3 |
damn that does sound pretty intimidating.
no 4 barrel either. Didnt want to drop more money intho this. thanks again. Hopefully someone else can chime in and have a cool hack |
08-09-2018, 11:14 PM | #4 |
If you really want to make yourself crazy, try it with dual carbs!
I have not actually got this up and runnin' yet, but after mucho trial and error, I'm confident that I finally have it right. This picture would be at idle: And this is wide open: I have lots to do yet, but it's getting closer
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
08-11-2018, 12:54 PM | #5 |
wow pritch thats what im talking about ha.
Im already going crazy with just one. so u too used a v8 starter that was for how many teeth ur fleplate had? |
08-12-2018, 12:05 AM | #6 |
60-66 Nut
Now that I think about it some more, I believe the 292 requires a specific flexplate since the crank has 2 dowel pins and larger 1/2" bolts. I believe there is info here in this forum about it.
Edit: Here is some more info for you. http://www.67-72chevytrucks.com/vboa...=292+flexplate
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-12-2018 at 12:13 AM. |
08-12-2018, 01:57 PM | #7 |
The one that came with my 700 fit no problem bolted right on
thanks captain fab |
08-13-2018, 11:17 PM | #8 | |
08-13-2018, 11:29 PM | #9 | |
08-14-2018, 05:27 AM | #10 |
My 292 is a manual [SM465]. There are 3 bolts on the starter. Two with the heads from the front, and one, higher up, from the back. All mounted in the bellhousing. All horizontal.
Engine is the original in my '68 C/10.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 08-15-2018 at 12:57 AM. |
08-14-2018, 10:48 PM | #11 |
I found some pictures I was looking for. This is how my stater mounts, with the 2 bolts going straight up from the bottom:
08-16-2018, 03:05 PM | #12 |
How ya like that 200 trans ?
08-18-2018, 09:20 PM | #13 |
I'll let you know when I get the thing up and runnin'
09-05-2018, 10:37 PM | #14 |
would still like some help?
im about to find out if the sbc starter bolts right in |
Thread Tools | |
Display Modes | |
