02-17-2013, 02:11 PM | #1 |
03 GMC 8.1 coil packs
Chasing a rabbit! 03 2500 HD 8.1 has 125k on it. The past few years in the winter when the temps change if you ran it a short distance and turned it off it didn't want to start the first few times or would cut off. Doing normal maintence
changed plugs and wires and fuel pressure regulator. Replaced coolant temp sensor and crankshaft positioning sensor. It still has the problem. After it starts I sometimes smell gas. It has sprung no trouble codes. Not sure about the coil packs. When you change or how you know one is weak or going bad. Thanks |
02-17-2013, 04:58 PM | #2 |
Re: 03 GMC 8.1 coil packs
i've been in the auto repair for many years and have yet to see a coil pack fail on any of the 5.3ls though the 8.1s
02-17-2013, 08:36 PM | #3 |
Same here. If you are smelling gas I would recheck the fpr, and do a pressure test to see if you may have injector or check valve leaking down.
02-20-2013, 10:31 PM | #4 |
Future TOTM Winner
EDIT...nevermind, you already tried my suggestion.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 02-21-2013 at 12:46 AM. |
02-21-2013, 10:37 AM | #5 |
Changed the fuel pressure regulator yesterday. When I pushed the valve on the fuel rail to relieve the pressure it had a ton on it. What was different. When I pulled the old regulator the bowl filled up with gas. I dried it out and it did it again. Put the new one in worked fine yesterday. This morning the same thing. started right up ran for 30 minutes. went inside came back hour later didn't want to start. finally did and I smelled gas. It finally gave me one code for bank one senor one oxygen sensor.. haven't changed it out yet. Cleared the code to see if it would do it again but it has not
