Old 10-11-2011, 11:26 AM   #1
slns831
slns831's Avatar
1970 C10 Rear Bumper Bracket Pictures Help!
Hey Guys! I'm in the process of installing rear bumper brackets for my
70 C10 shortbed fleetside. Anybody have pictures of these brackets mounted on to the frame? I'm sure this is a dumb request since it seems like a very straight forward install, but I figured it doesnt hurt to ask? Thanks!
slns831 is offline   Reply With Quote
Old 10-11-2011, 12:12 PM   #2
6772owner
Gearhead
6772owner's Avatar
Re: 1970 C10 Rear Bumper Bracket Pictures Help!
This is all I have from my install... but basically, the main brackets only line up to a few holes in the frame and the outer brackets go on the rear most bolts with the main brackets. The rock gaurds bolt down to the brackets on the top edge.... Let me know if you need better pics and I can get you some.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 10-11-2011, 01:10 PM   #3
57larry
are your brackets repo ? how's the fit if so. thanks
57larry is offline   Reply With Quote
Old 10-11-2011, 01:23 PM   #4
6772owner
Gearhead
6772owner's Avatar
Yes sir, I think I got them from Classic Industries (I will have to check), they fit great for aftermarket/re-pop. I was pleasently surprised how well the bumper lined up really.
Old 10-11-2011, 01:38 PM   #5
slns831
slns831's Avatar
Thanks for the pics! I purchased my repo brackets from Classic Industries as well! Hopefully they line up good like yours!
Old 10-11-2011, 04:14 PM   #6
6772owner
Gearhead
6772owner's Avatar
No problem, I hope so! I was nervous that they wouldn't even fit with all the other junk I have/had going on at the back of the frame... Make sure to post up some pics when you're done.
Feel free to PM me and Ill give you my cell if you need any help with the install.
Old 10-11-2011, 04:24 PM   #7
slns831
slns831's Avatar
Will do! Thanks again!
Old 08-19-2012, 01:13 PM   #8
Omar13
DId you have any pics of the rear bumper installation i'm having trouble with the brackets, help.... thanks
Omar13 is offline   Reply With Quote
Old 08-14-2015, 03:38 AM   #9
Farmboytrucks916
I to would luv to see this, I bought some aftermarket brackets for my new rear bumper aswell but am having a hard time getting it to line up unless I refab the brackets or weld them in. this is on a 67 gmc c15 with leaf springs not sure if that matters.
Farmboytrucks916 is offline   Reply With Quote
Old 08-14-2015, 05:20 AM   #10
Xeen
Xeen's Avatar
You will notice the brackets have holes on one edge towards the bumper end, install them with the holes up and they are installed correctly.
Leave all bolts loose until you get the bumper in the desired position and then tighten it down.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 08-14-2015, 12:59 PM   #11
BrianG
BrianG's Avatar
Thanks for the picture. I've heard that the bolts can be overtightened causing appearance issues from the outside. Did you torque the bumper bolts to a certain spec, or just untill they felt tight?
BrianG is offline   Reply With Quote
Old 08-14-2015, 02:43 PM   #12
Xeen
Xeen's Avatar
These aftermarket fleetside sport bumpers are super flexible, I don't know why they make them like this because the stepside version is stiff, anyways I sit on the top of the bumper while I tighten the bumper bolts and it doesn't bow as much at the top.
The bumper bolts don't have to be super tight, I used a washer and a lock washer and just tightened it until I was satisfied that it wasn't going anywhere and it wouldn't rattle.
Old 08-14-2015, 05:36 PM   #13
Farmboytrucks916
Old 08-14-2015, 05:36 PM   #14
Farmboytrucks916
My brackets have a hump in them let me get some pics and I'll post.
Old 02-06-2023, 10:25 AM   #15
NJ68stepside
Search works great! This site is way better than the assembly manual
Needed this pic, Thank you!
Please be patient. I’m a ford guy. This is my 1st Chevy.
Previous cars:
1973 mustang convertible
2003 mustang Mach 1
Now building resto mod 68 C10 step
NJ68stepside is offline   Reply With Quote
