02-11-2015, 07:09 AM | #1 |
Late model Crossmember needed???
I received quote on prices from Stan at ECE... 4/6 drop, disc power brake upgrade, and power steering upgrade... Then I mentioned that I bought donor truck to pull LS 5.3 and 4L60E. And he asked if I was replacing the front cross member.
So do I need to replace my front cross member for the LS motor? What benefits does the later model cross members have, if any? Jimmy |
02-11-2015, 08:39 AM | #2 |
Re: Late model Crossmember needed???
No you don't need the later crossmember, it is just the parts are much cheaper when replacement time comes. Jim
02-11-2015, 10:21 AM | #3 | ||
Mark
Retired Air Force/Disabled Vet 1969 Chevy C-10, On the way to greatness! Last edited by WiggyHD; 02-11-2015 at 10:26 AM. Reason: Update info |
02-11-2015, 10:45 AM | #4 | |
Jimmy |
02-11-2015, 11:59 AM | #5 |
These: http://www.earlyclassic.com/catalog....ry=New%20Items
or, These: http://dirtydingo.com/store/LS-Conve...322/index.html will work with my 69', but I don't know what year you have. The early classic kit comes with the 73'-87' frame mounts. That's why they want to know if you have already swapped the crossmember. Look into the engine swap section under lsx swaps and review people builds. This is where I get a lot of what I have learned. Mark
Retired Air Force/Disabled Vet 1969 Chevy C-10, On the way to greatness! |
