Old 08-22-2017, 12:37 PM   #1
Matt58
1966 Stock 4x4 chassis
Recently picked up a 66 K10 short fleet and would like to see some pics of front and rear stock suspension so i can compare to what i have. Thanks
Matt58 is offline   Reply With Quote
Old 08-22-2017, 01:52 PM   #2
61K10
61K10's Avatar
Re: 1966 Stock 4x4 chassis
Post some pics of what you have. Might get more info. My 61 is a little different in shock mounting.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-23-2017, 12:52 AM   #3
'63GENIII
'63GENIII's Avatar
Agreed. We're a bunch of picture mongers! Seriously though, you'll probably get more responses with a handful of pics of what you have.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 08-23-2017, 11:20 AM   #4
Matt58
thanks guys i will try to get some pics for you....
Old 08-23-2017, 06:17 PM   #5
Matt58
here they are
Old 08-24-2017, 02:27 AM   #6
'63GENIII
'63GENIII's Avatar
From memory it looks identical to what my '63 came with.
Closed knuckle Dana 44
T221 T case
12 Bolt rear - This is the only difference I could see. It looks like the shock mounts on top have been moved inward towards the center and that the lower mounts (the ones hanging down off of the axle) have been abandoned and relocated?
Chris
'63 k15 long step
Old 08-24-2017, 02:30 AM   #7
'63GENIII
'63GENIII's Avatar
The rear bump stops and lift blocks look the same as mine.
The front bump stop mount are below the frame as opposed to on the outside of the frame. Could be a small model year change?
Chris
'63 k15 long step
Old 08-24-2017, 02:50 AM   #8
'63GENIII
'63GENIII's Avatar
Some pics. Kinda crappy though.
1st pic is of the front axle original front spring hanger before I cut it out. Cast iron with the grease pins. Don't mind the second leaf spring in the pic. It was there for comparison.
2nd is of the front shock and at what appears to be the top of the shock boot you can see the bump stop bracket hanging off of the side of the frame with the slot in it. The rubber bumper would attach to that slot.
3rd pic is of the shock absorber mounting. The rear shocks on my '63 run more or less parallel to the frame and slant forward. They attach to brackets on the frame with a 3/4" bolt that runs all the way through the bracket and the frame. The lower shock mounts were originally on the 12 bolt that it came with. I cut those off and welded them on the Dana 60 that was in it for a while then cut and relocated the lower shock mounts that were on the 14 bolt to match the location of the originals.
Hope this helps.
Chris
'63 k15 long step
Old 08-24-2017, 01:07 PM   #9
61K10
61K10's Avatar
Like Chris said looks factory stock. Just for info some pics of my shock mounting as yours looks modded. can't really tell. My top ft shock mounts are modded. (pic of the ft mounts i cut off) Your ft shock upper mount should go through the frame.
1961 chevy K10
Old 08-25-2017, 09:35 AM   #10
Matt58
Thanks guys. Good to know its mostly original under there...
Old 08-26-2017, 10:02 PM   #11
Short 3/4
The front bump stops on my 65 are also outboard, but yours look stock so probably a 66 only thing
Short 3/4 is offline   Reply With Quote
Old 09-11-2017, 05:41 AM   #12
j.kirn
your frame looks to me like it is a 60-62 frame, with newer rear axle
j.kirn is offline   Reply With Quote
Old 09-11-2017, 12:26 PM   #13
61K10
61K10's Avatar
I think you are right Joe. Looks just like my 61 frame. rear upper shocks are like mine and it has a front motor mount on the x-member.
1961 chevy K10
