10-12-2017, 10:06 AM | #1 |
Question For HVAC guys
My house unit developed a leak and lost all the refrigerant...I had a tech come out and repair and refill it...
the king valve was where the leak was and all he did was apply some "gorilla snot" and tighten the cap down..pulled a vacuum and refilled with 17 lbs of R410A.....charged me $895.00.... my question...is the R410A refrigerant that expensive....I looked on Ebay and a 25lb bottle was around $150...
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
10-12-2017, 10:45 AM | #2 |
Its a Truck Thing......
Re: Question For HVAC guys
What was his labor rate? I would get a second opinion for that repair technique from another company for what he charged. You will be shocked at what some of these companies charge for labor. It is all about the mark up......If you can buy R410A online for less than $125 than they can get it cheap too. Just depends on where his source of supply is coming from but, shouldn't be that much more in cost.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
10-12-2017, 10:53 AM | #3 |
He should guarrantee his work!
Call him and tell him it didn't work and he needs to replace the valve. For that amount of money,he should do it right-No half-azz patching! If he doesn't repair it at no cost,call the BBB and report him!Is he licensed? And,don't use the same guy again. I'm a retired electrical/ac contractor and I hated going behind idiots like this! Mike. |
10-12-2017, 07:40 PM | #4 |
OK you got ripped, there is no way your residential A/C system hold 17 lbs of refrigerant .
even if you had 300ft of lineset (copper Tubing ) you could not have 17lbs in your system. Do yourself a favor look at the tag on your unit write the make and model number down call the manufacture of your condenser and ask them how much that system holds with 50ft of linset , most house on average have about 35 ft of copper (lineset) and see what they tell you at best your system hold 6 lbs of refrigerant. and that is bone dry with a vaccum put on the system , typical HVAC ripoff service company |
10-12-2017, 08:39 PM | #5 |
I do all my own hvac. How hard would it be to have put in a $2 valve. Recharge would be about $75 if done right. At his prices I have saved myself tens of thousands!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
10-12-2017, 10:22 PM | #6 |
r410a systemw use more refrigerant than r22 but that seems about right i have put 24lb in a 10 ton system. we charge 20 bucks a pound for r410a 92hr should not have taken but 2 or 3 hr
10-12-2017, 11:20 PM | #7 | |
Op the factory charge is on the data plate, this is what the condensor holds and will typically get you within 2 lbs of total charge. It sounds like his repair method was the easy route, if it was the large brass cap on a service port it's typical and has worked before though. I'm a small 2 man shop in south Alabama, we get a 25lb drum of 410A for around 150, and sell it $25.00 a pound. Repairing leak (assuming simple brazing), vacuuming system would be around 2 hours. Also assuming you actually needed that amount of refrigerant cost would be around $550.00 I know this is comparing apples to oranges, just giving my insight on this. Hope it holds up, sir! |
