Old 11-05-2017, 08:28 PM   #1
56hotrodred
Vent cables and knobs
I want to keep my fresh air vents and want to get the cables and knobs and operate them from the two upper outside stock holes in the dash-the choke and throttle holes I think!
For those of you who have done this what cables did you use and where did you get them and the knobs. Are the knobs interchangeable as I would want them all to match on the dash.
Thanks in advance for any help.
56hotrodred is offline   Reply With Quote
Old 11-06-2017, 01:26 PM   #2
_Ogre
_Ogre's Avatar
Re: Vent cables and knobs
the stock cables won't be long enough to reach either side but i don't see why you couldn't modify them
you'd need to start with the throttle and choke cables as the vent cables won't dash mount to well
then add the vent cables to the existing dash cables to make them longer
no way to add on to either cable or housing, you'll need to make a splice block
start the mockup by clamping the housing to a board and clamp both cables together
once you get a plan from the mockup make the final version from steel
clamp cables together with something like this from orielleys
just drill out the hole to accept both wires
clamp the housing down with something like this
photosuckit fix for chrome
Old 11-06-2017, 05:13 PM   #3
Dan in Pasadena
Dan in Pasadena's Avatar
Originally Posted by _Ogre View Post
The stock cables won't be long enough to reach either side but I don't see why you couldn't modify them.
You'd need to start with the throttle and choke cables as the vent cables won't dash mount too well.
Then add the vent cables to the dash cables to make them longer.
[There is]no way to add on to either cable or housing, [so] you'll need to make a splice block.
Start the mockup by clamping the housing to a board and clamp both cables together.
Once you get a plan from the mockup make the final version from steel
Yikes, Ogre! Your post gave me a headache without any punctuation. Added some so others wonít get the same. I hope you donít mind.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 11-07-2017, 12:18 AM   #4
roger55
roger55's Avatar
I did exactly that with my truck. Replacements are long enough.
They are cut to fit.
Got them here:
https://www.classicindustries.com/pr...ts/cx1174.html
roger55 is offline   Reply With Quote
Old 11-07-2017, 12:53 AM   #5
Dan in Pasadena
Got them here:
Roger,
Youíre saying the replacement vent door cables are long enough? Then how did you mount the knobs to the dash? Some kind of mod like Ogre proposed or was there some way you did it with the vent door cable?
Old 11-07-2017, 12:57 AM   #6
roger55
roger55's Avatar
Yes. They are long enough.
You take that small bracket off behind the knob. They have threads and a nut to mount them to the dash.
You can get them with black knobs or chrome ones. Here's the black:
Old 11-07-2017, 01:20 AM   #7
56hotrodred
There you go! Thats what I was looking for. Will be placing an order this week.
Thanks for all the good advice.
Old 11-07-2017, 11:56 AM   #8
_Ogre
_Ogre's Avatar
oh oh the language police have found me again
i'll have to go back to the witness protection program and change my login name
Old 11-10-2017, 09:33 PM   #9
my56chevytruck
my56chevytruck's Avatar
haha, I followed your input quite clearly, Ogre. If you change your name, will you be repainting your truck to??
RUBBER DOWN AND HIT THE ROAD!!!
my56chevytruck is offline   Reply With Quote
Old 11-10-2017, 09:36 PM   #10
my56chevytruck
I mounted mine as Roger55 did and had sufficient cabling to have them work from the upper location
Old 11-19-2017, 03:03 AM   #11
MiraclePieCo
There, their, they're...it'll be okay.
MiraclePieCo is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
