Old 11-12-2017, 07:11 PM   #1
Kevin Mac
Junior Member
Kevin Mac's Avatar
How much is too much (lower ball joint interferance)
I have been working on replacing all control arm bushings and ball joints on my G body front clip. Everything was going fine until I tried to install the lower ball joint. It has .020" interferance and it just seams like it is too tight to go in the hole. I bought Moog parts thinking they would be good. I think .010" would be plenty for interferance fit. I may run a flapper wheel in the hole to loosen up a touch. What do you guys think?
Thanks Mac
Kevin Mac is offline   Reply With Quote
Old 11-12-2017, 08:09 PM   #2
HUSSEY
HUSSEY's Avatar
Re: How much is too much (lower ball joint interferance)
I can't comment on what the proper interface should be I experienced what you're experiencing. I also used all Moog parts to redo the front end on my S10 chassis swap. I had the control arms out when I went to put in the lower ball joints and they were a mother to get started and fully pressed in. I was using a ball joint press which looks like a big beefy u-clamp. I could only get them in so far with the control arms off the chassis with an impact. I had to put the control arm back on and use a long breaker bar to get the joints fully seated.
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 11-12-2017, 08:21 PM   #3
Kevin Mac
Junior Member
Kevin Mac's Avatar
Wow. I went to parts store and measured a Moog and a cheapie and they both measured the same as mine. I need a press!! Thanks.
Mac
Old 11-12-2017, 09:33 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
Mac
The aftermarket are larger because you press in and out the originals and that stretches the hole somewhat. .020 is to make sure you have a tight fit if the hole is stretched. You always press them in, you can knock them out with a hammer or put them in with a hammer your a frame is bad
Old 11-12-2017, 11:28 PM   #5
MiraclePieCo
Always sand/grind on the item that easiest/cheapest to replace. IOW, grind on the bushing, not the control arm - grind on the tie rod end, not the spindle steering arm. I learned this lesson by having to buy new control arms.
MiraclePieCo is offline   Reply With Quote
Old 11-13-2017, 12:16 AM   #6
Kevin Mac
Junior Member
Kevin Mac's Avatar
I got it in, the reason I was concerned was the metal was starting to split where it is rolled out from the stamping. That made me want to research a little.
Mac
Old 11-13-2017, 04:31 AM   #7
mr48chev
mr48chev's Avatar
What A arms are you putting the ball joints in? When I was doing front end work I used to run into some GM lower A arms that were a bit sloppy and wouldn't hold a ball joint tight. I took a center punch and staked some and replaced others. Even tack welded a couple of ball joints in place when the owner didn't want to spend extra money on them.
That said, I wouldn't grind on them to get them to fit.
If you can't fix it with a hammer, you have an electrical problem.
My ongoing truck projects:
Old 11-13-2017, 09:34 AM   #8
Kevin Mac
Junior Member
Kevin Mac's Avatar
1979 stock G Body A arms.
Old 11-13-2017, 05:09 PM   #9
mr48chev
mr48chev's Avatar
Are you using a ball joint press or ?
Old 11-13-2017, 09:25 PM   #10
1958Warrior
1958Warrior's Avatar
I used the BFH and some anti-seize and a piece of pipe as a driver, didn't have any fancy tool at the time. However I did go buy a press off CL for $75. For next time.
You could always pick up a press off CL and just resale it when your done, they seem to sell quick.
They do sell oversized ball joints, for the sloppy A arms ,I've never ran into the need to use one yet
1958Warrior is offline   Reply With Quote
Old 11-13-2017, 10:25 PM   #11
Kevin Mac
Junior Member
Kevin Mac's Avatar
Warrior and 48, I used the BFH method also. Took the other side apart tonight but didn't try to drive that one in yet. I might drop it off at my mechanic's shop tomorrow and see if he will press it in for me.
Mac
Copyright ©2000 - 2018, vBulletin Solutions Inc.
