Old 01-03-2018, 01:01 PM   #1
J3rm0ff
Is a notch needed to sit level on bags
I have tried searching but have not had much luck. I have 2.5" drop spindles in the front with plates and cups for the bags. In the rear I am doing bags on trailing arms in the stock spring location.
Will I need to notch the rear so that it sits level aired out? If so how much?
Not trying to lay frame just want it to sit level.
J3rm0ff is offline   Reply With Quote
Old 01-03-2018, 01:25 PM   #2
hewittca
hewittca's Avatar
Re: Is a notch needed to sit level on bags
When aired out, the front will sit lower even with a notch in the rear. You might as well go ahead and put in a notch. Any standard notch will do as they are as deep as you can go before the center of the rearend hits the bedfloor.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 03-04-2018, 10:34 AM   #3
rustynut
rustynut's Avatar
X2...notch the rear and if the suspension is configured correctly the truck should lay out level, unless the rwar driveline doesn't clear the crossmembers or lthe tunnel of the cab.
rustynut is offline   Reply With Quote
