06-12-2018, 05:24 PM | #1 |
stock spring specs Help please
with my truck now in super capable hands I've been asked the question of what the standard spring spec/size/weight rating is for both front and back.
I've checked on the usual sites but can't seem to find the info - to add logic to this my mechanic is aiming to have the springs made locally, slightly lowered but to meet the same (or better) standard specs. Hopefully I can get some urgent help Thanks Glenn |
06-12-2018, 11:56 PM | #2 |
60-66 Nut
Re: stock spring specs Help please
I can't help with the specs but if you are going with a lowered spring I would think it would be more cost effective to just buy them from here in the US.
06-13-2018, 03:59 AM | #3 | |
Thanks for the input |
06-14-2018, 10:57 AM | #4 | |
06-15-2018, 06:25 AM | #5 |
I did a bunch of research on spring rates and they vary a good bit based on rate and use. A hotchkis spring will be stiffer than a CPP. A good spring shop will want wheel weights, total weight, installed height and use. If you are going to auto cross the truck the rates will be stiffer than the rate on a cruiser that is looking for the smoothest ride.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
