Old 06-12-2016, 10:25 PM   #26
Praxiss454
Praxiss454's Avatar
Re: Newbie thinking about diving into a '65 GMC 1000
Well, I went and took a look at it. Body seems solid. Trying to identify what engine it has in it. I snapped a couple of pics but I can't seem to find info on the numbers. I must be reading them wrong.
This is right next to the spark plugs. Looks like it says 4883F20 or maybe 1883F20. Neither of these numbers yielded anything on various sites I've checked.
And here is another stamp on the exhaust manifold (I think?). 3820578, or maybe 3829578. Hard to say. The 382 part seems pretty clear but even that yielded nothing.
Any ideas? Tonight after my daughter goes to sleep I'll post more of an update on the truck, along w/ a few more pics.
Cheers
Praxiss454 is offline   Reply With Quote
Old 06-12-2016, 11:52 PM   #27
Praxiss454
Praxiss454's Avatar
Okay, here is what else I found out.
1. Generally the body is in pretty good shape. The only part that looks to have been previously (and poorly) repaired is the left rear panel. Looks like there is a bit of bondo, and then I guess the guy got in another accident? Not really sure. The bed of the truck is all rotted wood, but it looks like the hardware is still there.
2. There is some funky wiring going on.
<EDIT: picture disappeared - check later post>
We put in a battery, hooked up some new gas, and tried to fire it up. The push button ignition would turn over, but it wouldn't catch. Discovered the spark plugs were not sparking. Tested the voltage on either side of the coil, and it wasn't getting any juice. Figured somewhere in the wiring nest something wasn't connected, so I jumped from the battery directly to either side of the coil. Not sure if this was advisable, but in any case it didn't work, and we still didn't get a spark. HOWEVER, when I jumped in this fashion, the dash indicators all turned on and started working. They previously were all dead, and I assumed it was a fuse problem.
I also wanted to see if it would roll, so popped it in neutral and my buddy hooked up a tow strap. We moved it about 30 ft in neutral while I tested the steering and brakes. Pedal brake didn't work, but hand brake did.
So, I'm feeling pretty good about the truck. It needs a ton of work, but I feel like I can figure out this electrical gremlin and get it running. With a bit of cleanup and minor maintenance I think I'd be in business.
We haven't finalized a price yet, but I am planning to make an offer this week.
Last edited by Praxiss454; 08-14-2016 at 01:03 AM. Reason: Problem with photos showing up.
Old 06-13-2016, 12:05 AM   #28
Captainfab
60-66 Nut
That engine appears to be an I6? You need either the casting numbers on the rear drivers side of the block or the code stamped on the pad close to the distributor.
Old 06-13-2016, 12:10 AM   #29
TJ's Chevy
TJ's Chevy's Avatar
I'd bet money that's a 230 or 250. Engine numbers will be on the lower side of the Block near the starter.
If the side covers are 4 inches tall it's a 230 or 250.
6 inches tall it's a 292.
Dished pistons. 250
Flat top pistons. 230 Easiest way to tell.
Old 06-13-2016, 12:17 AM   #30
jtrichard
The wiring plug hanging down is where the IGNITION switch (that is missing) belongs
jtrichard is offline   Reply With Quote
Old 06-13-2016, 01:08 AM   #31
Praxiss454
Praxiss454's Avatar
That was my guess. Someone wired it w/ a push button that worked, but there was no "on" position as far as I could tell. If/when I buy the truck I'll be putting in a keyed ignition again.
Speaking of engine components and locations -- is there a good exploded view diagram or microfiche that shows a '65 engine compartment, and in particular, a 230 ci engine?
Old 06-13-2016, 05:25 AM   #32
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
I'm sorry but I only have Chevrolet locating info from 1963. You can use the link and then the magnifier to be able to read the info.
https://photos.google.com/photo/AF1Q...gL5qQpbkhPn0WF
Old 06-13-2016, 04:52 PM   #33
Praxiss454
Praxiss454's Avatar
Thanks aerotruk63, I tried to buy a pdf version of a service manual before going but the only thing I could find was a CD-ROM version that would take a few days to arrive via snail mail. I'm picking up a used Chilton manual this week.
By the way, one of your pictures didn't load. I had similar issues when trying to share mine from Google Photos.
Old 06-13-2016, 05:13 PM   #34
jtrichard
Prax your pic was there,now it's gone it was the one with the ING. switch wires.... If you get the truck one thing i would do is trim those WINGS off of the rear bumper they are great for screwing up the bed sides (see drivers side)
Old 06-13-2016, 11:30 PM   #35
Praxiss454
Praxiss454's Avatar
Well, I've officially made an offer on the truck. Now we wait...
Old 06-14-2016, 01:10 AM   #36
Praxiss454
Praxiss454's Avatar
Any he's accepted it after a bit of back and forth!
Now I just gotta figure out how I'm going to tow the thing the ~140 miles home to Novato.
Old 06-14-2016, 06:39 AM   #37
aerotruk63
aerotruk63's Avatar
You can borrow my car hauler & dually, just that it's a 7 hr flight, 43+hrs of driving one way, but then, I'll go for the ride with you, and then haul something back. All expenses paid by you. I know, such a kind offer
Old 06-14-2016, 11:55 AM   #38
Praxiss454
Praxiss454's Avatar
What a guy!
Old 06-14-2016, 01:26 PM   #39
TJ's Chevy
TJ's Chevy's Avatar
OR, I could pick it up and bring it to my house!
Old 06-15-2016, 11:35 PM   #40
Praxiss454
Praxiss454's Avatar
I don't know if this photo is going to work, but, behind and to the left of the ignition switch plug, there is a round black plug socket, with one white-ish wire coming from ignition switch.
What is that round black component? Having a hard time getting a good visual of the wiring components and my chilton manual doesn't have very good pics.
Old 06-16-2016, 12:03 AM   #41
jtrichard
I think its the brake light (hard to tell the angle in the pic) switch BUT not wired like that ( if it hooks to the ING. switch) brake switch should have an orange (power) and a white to the turn switch
Old 06-16-2016, 12:08 AM   #42
Praxiss454
Praxiss454's Avatar
Originally Posted by jtrichard View Post
I think its the brake light switch BUT not wired like that brake switch should have an orange (power) and a white to the turn switch
Thanks jtrichard. You can kind of see, there is an orange or red wire hanging down right in that area that has the same kind of connector cap as the white wire. I assumed it should be plugged in there but it wasn't when I took the picture.
EDIT: But if this is in fact the ignition switch connector, there is no way those two would have otherwise been hooked up because this wouldn't reach all the way to the stock ignition location. So yeah, I'm still confused.
This is the old manual that came w/ the truck. It has a ton of info but is the majority of it is not relevant to my specific make/model/options.
Old 06-16-2016, 01:13 AM   #43
jtrichard
The orange and white wire may not even be hooked to that connector HARD to make out just what is going on with that rats nest with only one pic ...... hard enough in person let-alone with pics ... and chitlins covers to many years to be very helpful
Old 06-16-2016, 09:12 PM   #44
Praxiss454
Praxiss454's Avatar
You need to check with DMV and see if it is NON-OP'D IF yes then it is worth at least $1500 ..... The bed alone is worth about 1200/1500 and the license plates about $200 with the truck (if you want correct plates for the year)
Good news from DMV. Title is now transferred and registered to me, and I get to keep the plates. The lady @ DMV said it appears those are the original plates, or at least a previous owner had proof the # was registered w/ that truck in the past.
Old 06-18-2016, 07:37 PM   #45
Praxiss454
Praxiss454's Avatar
According to some eBay searching, it looks like my hubcaps are from a late 70s Impala police car. Makes me wonder if the wheels are from the same.
Old 06-18-2016, 09:23 PM   #46
jtrichard
The answer on wheels should be NO as the car would have 5 lug and the truck should be 6 (unless upgraded)
Old 06-18-2016, 09:30 PM   #47
Praxiss454
Praxiss454's Avatar
The answer om wheels should be NO as the car would have 5 lug and the truck should be 6 (unless upgraded)
The stock 15" truck wheels were 6 lug? I thought they were 5. I see conflicting info on this though. I suppose I'll see what I have tomorrow when I go pick the truck up.
Old 06-20-2016, 11:56 AM   #48
Praxiss454
Praxiss454's Avatar
Sure enough, it is 6 lugs.
Old 06-20-2016, 06:02 PM   #49
C/10 King
C/10 King's Avatar
Post more pic's!!!!
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 06-20-2016, 11:40 PM   #50
Praxiss454
Praxiss454's Avatar
I didn't do a very extensive cleaning, just wanted to wipe off some of the heavier grime.
Before:
After:
So, when some PO converted to a push button starter, they also apparently replaced the ignition switch plug. Which means the new ignition switch I bought from lmc does not fit. I guess I'll try to track down an OEM style ignition switch plug to hook it back up.
