06-02-2013, 02:21 PM | #1 |
Sway Bar Bushing Clamps
06-02-2013, 02:27 PM | #2 |
Re: Sway Bar Bushing Clamps
Aftermarket bushings come w/the brackets. Prob won't find many left on dealership shelves but salvage yards usually have them.
06-02-2013, 06:54 PM | #3 | |
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
06-03-2013, 07:01 AM | #4 |
Watch out for your cornhole !
That picture is one of mine. The part number written on the cardboard is still a viable GM number. My dealership keeps them in stock. Just walk in and tell them how many you want.
06-04-2013, 08:09 PM | #5 |
Hey TX Firefighter! it is your picture from you how to install sway bar thread. good write up btw helps out alot.
i did get sway at junk yard but wasnt able to get two clamps. think i might just go back and get clamps at the yard cuz the closest dealer with them in stock is further than the yard. thanks for the replies guys. |
06-05-2013, 08:28 AM | #6 | |
06-05-2013, 01:07 PM | #7 |
How does that improve it? I read it somewhere else but I don't get how it works. Is it something you can't explain and just know it works?
Posted via Mobile Device |
06-05-2013, 01:35 PM | #8 |
OE rubber bushings have a lot of excess material which allows movement/flex from deflection. Poly bushings deflect much less. When used in the frame position they allow the sway bar to pivot up/down w/o deflecting. Think of it like a 35 series Z rated tire on a Vette to a 75 series tire on a van. Shorter, stiffer rubber offers better (more precise) control of what ever it contains. Using the OE brackets w/aftermarket (parts store) bushings @ the control arms offer better control vs factory rubber w/o the binding associated when using poly in this position.
06-07-2013, 12:39 AM | #9 |
Thanks for explaining that for me. Maybe later I will I already had bushings.
I ended up going back to the junk yard for the brackets ha ha ha thanks guys. Posted via Mobile Device |
