Old 05-09-2019, 04:09 PM   #1
72timemachine
Any decent aftermarket cv axles out there?
I have to replace the front cv axles on my friend's 2003 Silverado 1500. The hub bearings have already been replaced so they sound and feel fine.
I know there is a ton of tempting inexpensive cv axles out there but I would like to install something of quality and not have to replace these components in the next year or two simply to save a few bucks.
I do not feel he can afford GM oem components so would anyone out there happen to know of a brand that has some decent durability for a reasonable price?
Thank you for any help.
72timemachine is offline   Reply With Quote
Old 05-10-2019, 12:52 PM   #2
shifty
Questionable
shifty's Avatar
Re: Any decent aftermarket cv axles out there?
You may want to ask a mod to move this into the 99-06 forum.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 05-10-2019, 04:33 PM   #3
1976gmc20
I think they're all the same part 1988++ ...?
Anyway, I'll let you know in a year or two. Just put axles from O'Reilly's on mine. About $150 for the pair.
I will say that the "new" ones are a lot easier to put on than the old ones were to get off. The replacement parts came with the inboard flange cut in a semi-hexagon shape so it slips past the lower A-frame without any problem. If the ones I took off were OEM, I wouldn't want to ever have anything to do with those again.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 05-10-2019, 07:11 PM   #4
95 S_Trucker
95 S_Trucker's Avatar
There’s 88-98, there is 92-94 with 4 wheel abs, there is 99-07, then 07-13. That’s just for half ton. They aren’t interchangeable between the generations.
3/4 and 1 ton 88-00, 99-07, 07-10, 11-14.
You can’t take a cv axle meant for a 90 and put it on your 2003.
95 S_Trucker is offline   Reply With Quote
Old 05-10-2019, 08:52 PM   #5
1976gmc20
Okay, it just seems like when I was looking up the part online that the same part number fit a bunch of other years including post 2000.
Anyway, I'm sure the same aftermarket companies makes axles for 2003. I had to buy two different brands because they only had one of each brand in stock at the little O'Reilly's store, and I didn't want to make another 50 mile round trip.
