09-21-2018, 04:36 PM | #1 |
Lengthening hood release cable?
Wondering if anyone has lengthened their hood release cable? I need to lengthen mine 6-8" so that it doesn't go over my newly powdercoated inner fenders and then I can route it along the side of the driver's side fender to keep the engine bay neat. I was thinking of cutting the cable about 8" from the hood release bracket, and splicing in a section to extend the hose. I was thinking of maybe using some Lokar parts, but haven't found anything truly suitable yet:
77 C10 Silverado SWB - LS Swap, mechanical resto-mod 05 Z71 Silverado RCSB - 5.3L LM7, 76mm turbo, 4L80e |
09-21-2018, 05:03 PM | #2 |
Re: Lengthening hood release cable?
Go to a bike shop.
They deal in cables that might work. Or have something for a splice kit. Or try a big rig parts supply. They’ll have heavier stuff. Last edited by geezer#99; 09-21-2018 at 07:41 PM. |
09-21-2018, 06:54 PM | #3 |
I'm interested in this as well. My cable housing is broken right in the middle and the handle is broken. I wanted to buy a new cable, but I too want it to run along the driver's side instead of over the fender.
09-22-2018, 08:05 AM | #4 |
Might try a (70-72some) option bigger 73-87 GM B-Body car or Caddy 68-87 cable and handle. there longer and some have factory add on half way in the in-fender to the front fender ( two part cable ). You some time can mix and match the ends take pic's of yours both side go looking in the yards
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
09-22-2018, 10:00 AM | #5 |
mid eighties impala probably will work. been thinking doing that to my truck.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
10-16-2018, 06:59 PM | #6 |
I found a 91 Suburban in the yard and discovered it has a slightly longer cable (buy about 18" or so" than a 73-80 cable. I've wasted a lot of time trying to make something custom so I'll probably just stick with this Suburban cable for now, even though it's not as long as I would like.
I also found a 73 Buick sedan (huge car) that has a longer cable) and then a 75 El Dorado but both of those cables have brackets that are totally different where they bolt to the interior. I've wasted enough time with this darn hood cable but I did grab the El Dorado cable incase I get energy in the future. I'd have to fabricate some sort of L-bracket since the handle looks like this:
10-17-2018, 05:21 AM | #7 |
Please post pics of your routing when installed. I'm interested as my current one runs right across my battery.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
