11-17-2018, 01:01 AM | #1 |
Torque Converter??
Hey,
I am doing a TH350 swap in my 4x4 and need to know which TC will be best. It is a 70 GMC4x4 Short box stock 350 373 gears 33" tires QJet carbed HEI dis It is just a stockish 4x4. Not sure what stall I need. Thanks Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
11-17-2018, 04:00 PM | #2 |
Post Whore
Re: Torque Converter??
Just a ol bone stock converter should be fine .....
11-17-2018, 07:11 PM | #3 |
There seems to be differemt stall speeds on stock one. Just wondering whay is stock stall speed.
Ron
11-17-2018, 07:30 PM | #4 |
something close to 12-1500 rpm would work great...even at 1200, the taller tire and your gearing will give a couple hundred
11-17-2018, 08:30 PM | #5 |
Thanks Fellas.
Ron
11-19-2018, 10:59 AM | #6 |
If the stall speed of the converter is too low for the design of the vehicle's engine you'll need a firm foot on the brake pedal as it'll be pulling hard at a stop. Also torque in is torque out so a converter can stall at different RPM depending on the engine in front of it.
I think most GM V8 converters stall between 1600-1800 rpm. That should be appropriate for your engine.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
11-19-2018, 11:39 AM | #7 |
We put the Summit 1700-2000 rpm converter in my kid's Jimmy project. Haven't driven it yet, but with a little cam in it should make it a little peppier off the line and make it easier to hold at a light as mentioned above. For $108 and needing a converter in the rebuilt trans seemed a no-brainer.
12-01-2018, 08:34 PM | #8 |
Mike C where did you get your converter?
Thanks Ron
12-01-2018, 08:40 PM | #9 |
Summit Racing. It was like $108 I think.
Thread Tools | |
Display Modes | |
