09-26-2020, 05:47 PM | #1 |
Ray Mcavoy, can you identify these terminals?
For reference, these pics are of the Rockauto connector for the 1987 windshield washer pump.
The Mouser link is the correct connector, which seems to have something to do with "TE" and "AMP." What terminals am I looking for to install in this connector? I've learned my way around the Aptiv product line, but I'm clueless about "TE" stuff. https://www.mouser.com/ProductDetail...YoegcAFQ%3D%3D
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
09-28-2020, 10:21 PM | #2 |
Re: Ray Mcavoy, can you identify these terminals?
Not 100% sure, but I think these:
https://www.ebay.com/itm/25-pack-Del...72.m2749.l2649
Insert clever text here: |
10-01-2020, 10:59 PM | #3 |
I could be mistaken, but I don't think GM ever used any of those AMP / TE connectors as factory equipment. The one RockAuto is offering is basically just a replacement that will fit the application.
According to the factory wiring diagrams, the washer pump connector originally used Packard/Delphi (now Aptiv) 56-series female terminals in a #2973781 housing. |
10-01-2020, 11:09 PM | #4 |
This is interesting. For 67-72 trucks are there wiring diagrams (or other documents) that tell the housing numbers of all the various Packard/Delphi connectors all over the truck?
10-01-2020, 11:27 PM | #5 |
Unfortunately, I don't think GM started publishing the connector housing numbers on the wiring diagrams until around 1973 or so.
