Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-25-2009, 12:58 PM   #1
norske
New diz, lost torque
Put a rebulit HEI in my 305 and lost some torque. I'm assuming it's timing (what else?). The block and heads were shaved, block zero decked, erson cam (stage or two below a stump), eldebrock 2101 intake, Roch. Qjet, headers. I didn't check the timing before the diz went out (stupid!) so don't know where it was set. Put it at 10 degrees BTDC and it was better, but not quite there. Before I do too much testing, thought I'd ask you guys if you knew a ballpark figure for this setup. Thanks in advance.
norske is offline   Reply With Quote
Old 11-25-2009, 03:47 PM   #2
djracer
djracer's Avatar
Re: New diz, lost torque
I usually run as much as possible without pinging.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 11-25-2009, 03:50 PM   #3
turp mcspray
turp mcspray's Avatar
It may have a slower advance curve than your other one did. Do a search on timing, or timing weights and springs. You will find lots of info on how to dial in your timing.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 11-25-2009, 09:48 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
If its a msd they come with a lazy timing curve all in by 4k or something weird like that. my 406 likes 14 initial 36 total all in at 2500rpm
KQQL IT is online now   Reply With Quote
