03-24-2015, 04:26 PM | #1 |
Best EFI
I was thinking of getting an carburetor replacement EFI unit for my 350 and was wondering which is the best one to get or am I better of getting a hole new fuel injected engine? Also while my exhaust is currently out would it be a good time to install a O2 sensor even though it might be a while before I install the EFI?
03-24-2015, 05:14 PM | #2 |
Re: Best EFI
I've been told Holly is the best basic system followed by fast 2 but I'd like to hear from the experts.
03-24-2015, 09:07 PM | #3 |
Registered Truck Offender
Re: Best EFI
I'm running a Holley system,, one of the older Commander units. ALL of them have their quirks,, don't let anyone tell you different and if they do their lieing.
Basically the more functionality and adjustable parameters you have the HARDER it is to get set up right.... bt by the same token the more parameters you ARE ABLE to adjust, the better you will be able to tailor it to YOUR EXACT MOTOR AND CHASSIS. If you want EASY,, stick with a carb and don't worry about anything more than close. If your the kind of guy that likes to 'tinker' then the Holley and FAST is the system for you. Packages like Edelbrock and 'carb replacment' one size fits all is probably only slightly better than a carb. You know your dealing with a system that can rival the ECU in todays EFI cars if it has a wideband O2 option,, if it does, GET IT!!! All of them come with a pile of 'base tune' files to get you started. and they are kind of like 4Link and adjustable shock settings. Many people will plug in some base tune that seems close to their package,, then never spend the time to tweak it and hit the sweet spot. What that is saying is there is a point where spending $2600+ on a NICE EFI system is nothing but a 'feel good' buy
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
03-24-2015, 10:44 PM | #4 |
Re: Best EFI
Get a dyno tune and save $2300.00
At my worst I'm at my best |
03-24-2015, 11:09 PM | #5 |
Re: Best EFI
I got my carb rebuilt by PC carb, and it runs as good as anything. Also I was looking at a swap like you are before I got the carb rebuilt.
The price if admission is just to high for slight improvements on driveability. |
03-24-2015, 11:26 PM | #6 |
Re: Best EFI
Ok
1 what's it going in? 2 objective? High performance or reliability? LS swap if your in anything but a 4x4 67-72 and then it's still not bad but it takes some effort Now if you don't need to go fast just want reliability several out fits rework TBI units from the 87-95 era into stand alone very simple units. This is the way I'm leaning since I have a 72 4x4 |
03-25-2015, 12:06 AM | #7 |
Re: Best EFI
I like the MSD system, I don't have to move the fuel tank until I want to,
I like the Holley system, it looks like you can really tune that bad boy if you keep ugrading your engine, The Edelbrock system just doesn't hit me like they could have. The ONLY thing I don't like is the entry price. They just seem so dam expensive for what you get. If money wasn't an issue I'd pull the trigger on the MSD system and upgrade my ignition at the same time.
1966 Chevy C-10 350 Engine 700R4 |
03-25-2015, 12:11 AM | #8 |
Re: Best EFI
$$ is why unlike the reworked gm system it's under $1000 and gets you everything you need short of some fuel lines to get you rolling again not for super performance but my 93 has given me almost 300k trouble free miles and still gets 17 mpg.
03-25-2015, 01:00 AM | #9 |
Re: Best EFI
Interesting, I never knew about the reworked ones. Any websites about them that you might know of?
03-25-2015, 02:10 AM | #10 |
Re: Best EFI
On sent Dave.
03-25-2015, 02:36 AM | #11 | |
Re: Best EFI
They might have the parts at a local muffler or speed shop. http://www.summitracing.com/parts/sum-g2990 http://www.summitracing.com/parts/sum-g2990-1/overview/ http://www.summitracing.com/parts/lct-37616/overview/ |
03-25-2015, 01:03 PM | #12 |
Re: Best EFI
Nitis--post up the site so others will know.
1961 chevy K10 my build is------------61K10 build |
03-25-2015, 01:50 PM | #13 | |
Re: Best EFI
Me, I'm like you I like to fine tune the carb. I've also had great results tweaking the distributor as well, and one would be surprised just how good a well-tuned carb/HEI can really run. That's because not many people have actually done it, many people buy a carb/distributor and run them "out of the box". It's hit and miss at best, particularly on tweaked engines with cam/exhaust/heads mods. A bit of a PITA to tweak these things but that's the difference between something that runs acceptable and something that runs exceptional. And really, compared to all the things you have to go through just to install the FI, let along get the tune right, makes the carb/dist tweak seem easy, IMO even with the new wide-band O2 systems. BTW, I like the wide band systems but that does not change what I said. |
03-25-2015, 02:18 PM | #14 |
Re: Best EFI
how much elevation change are you guys typically driving in?
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
03-25-2015, 02:33 PM | #15 |
Re: Best EFI
03-25-2015, 05:33 PM | #16 |
Re: Best EFI
03-26-2015, 04:27 PM | #17 | |
Re: Best EFI
Not sure I agree that a well dialed carb will get better fuel mileage than a well set up efi system with O2 feedback. There are way to many variables and lack of real time compensation for a carb to do so. If we are talking a very controlled enviroment where temp/humidity/elevation are all controlled, maybe they could be close if not equal, but not to many of us drive around in a test lab
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
03-26-2015, 04:29 PM | #18 |
Re: Best EFI
The only reason I am thinking about getting one, is I want my 62 c10 to be a daily driver and I want it to start easy in the morning and not wait for it to worm up. Also I thought it might help on gas.
03-26-2015, 04:47 PM | #19 | |
Re: Best EFI
As an interesting side note: I know it's rare, but my Quadrajet has altitude compensating bellows on a third primary jet. http://www.crankshaftcoalition.com/w...4MV_carburetor |
03-26-2015, 10:21 PM | #20 |
Re: Best EFI
I had a question I have been wanting to ask for a while and this thread is the perfect place.
The "now aging a bit" 350 ramjet intake was saddled with a lousy controller? If better aftermarket stuff was added to the bare intake could a nice system be created? Would it support any power? I undertsand it would prob be expensive and an ls swap would make more sense, but since we are talking about aftermarket efi..
"You can take the man out of PA, but you can't take PA out of the man" |
03-26-2015, 10:36 PM | #21 | |
Re: Best EFI
I think an old MAF TPI computer, if you had the means of burning a chip or didn't mind paying several hundred dollars for a custom one would help out on an OBD1 application, anything beyond that you would have difficulty IMO because of the old ignition system coupled with if you wanted electronic controlled transmission. |
03-27-2015, 12:15 AM | #22 | |
Re: Best EFI
Using stock LS style EFI offers the flexibility of being tuned by EFI-Live & HP-Tuners, Diagnostics with normal scan tools & OE parts support. EFI Connection has everything you need... http://www.eficonnection.com/eficonnection/24x.aspx If starting with a post '96 Vortec engine, All you absolutely need from them is the 24X crank trigger wheel. Everything else can be sourced from OE parts suppliers. Tune the PCM for a standard firing order, Easy & tuning will be needed anyway, Or run a 4-7 swap cam to match LS firing order. Run 4L60E/4L80E transmissions with no hassles. |
03-27-2015, 12:51 AM | #23 |
60-66 Nut
Re: Best EFI
Several years ago, the guy that started EFI connection, bought a new Ram Jet 350 intake and built his own wiring harness to control it with an OBD I ECM. If you want to upgrade your Ram Jet 350, I would convert it to be controlled with an 0411 PCM. There is enough info on the internet on converting different OEM EFI systems to that PCM that it shouldn't be difficult to do. It may be as simple as using your existing wire harness and changing the plugs to the appropriate ones for the 0411 PCM. Then of course you will need a custom tune on the PCM. Or you can learn EFI-Live or HP-Tuners and tune it yourself.
03-27-2015, 01:03 AM | #24 | |
Re: Best EFI
03-27-2015, 01:21 AM | #25 |
60-66 Nut
Re: Best EFI
Here's the old post on that Ram Jet PCM conversion. It doesn't look like the pics are visable any longer though.
http://www.thirdgen.org/forums/tpi/2...t-350-p-n.html
