Old 05-18-2018, 09:03 AM   #1
Cam1968rsss
What size Carb? 400 sbc
Hi all, have 408 ci sbc (bored 40 over 6 inch stroke crank) have a Comp Cams 490 lift hydraulic cam 487 irons heads. Have two different Holley DP carbs, 650 and 700. Was wondering if anyone had an idea which would work better. Truck will have Turbo 350 trans, power brakes and power steering.
Cam1968rsss
Cam1968rsss is offline   Reply With Quote
Old 05-18-2018, 09:51 AM   #2
geezer#99
geezer#99's Avatar
Re: What size Carb? 400 sbc
Bigger is always better!
Actually either will work.
You gonna make enough vacuum to use your power brakes?
What stall?
What rear gears?
geezer#99 is online now   Reply With Quote
Old 05-18-2018, 09:59 AM   #3
Cam1968rsss
3.42 posi 12 bolt.
Stock torque converter.
Old 05-18-2018, 10:01 AM   #4
b454rat
Either will work if tuned. I had a 400 with a similar cam, had a Holley 600 on it, worked pretty good. I put a stock 3310 750 on it, ran like ****. Put that carb on a 350, and worked great. Who knows....also think you meant 6” rods, don’t think that stroke would fit in a small block lol
Old 05-18-2018, 10:49 AM   #5
Cam1968rsss
Yes this 400 has a stroked 6 inch crank and rods in it instead of a 5.7. Came from Skip White Performance out of Kingsport Tennessee. Am told this will be a torque monster once I get it broken in. Just wondering about which carb would be best.
Eddie
Old 05-18-2018, 11:13 PM   #6
Captainfab
60-66 Nut
Since both are double pumpers, I would go with the 650.
Old 05-19-2018, 09:04 AM   #7
cadillac_al
I would try them both. I would run the 650 for a few weeks and then try the 700 to see how much difference it makes.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 05-19-2018, 07:55 PM   #8
Dead Parrot
Found this: https://www.summitracing.com/experta...cfm-calculator
Shows for your size motor @ 5000rpm a street cfm of about 500 and a racing cfm of about 650.
Dead Parrot is offline   Reply With Quote
Old 05-19-2018, 10:59 PM   #9
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
I think you'll find the throttle response and idle quality better with the 650, so that would be my choice.
-Automatics win races, 6-speeds impress high school kids
-Save a tree, support your local dragstrip.
-"Failure - The Secret To Success, the idea is that you can fail 100 times as long as you can succeed once" -Takeo Fukui
columbuscarsandcoffee.net and on Facebook
ProStreet68SB is offline   Reply With Quote
Old 05-19-2018, 11:25 PM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
You're gonna hate that stock converter...
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 05-25-2018, 02:43 PM   #11
Tom
driving is in my blood
Tom's Avatar
You do not have a 6" stroker crank. You might have a stroker crank of some size along with 6" rods vs stock 350's 5.7" rods, but why you brought that up since a 400 uses 5.56" rods is confusing.
Old 05-26-2018, 11:19 PM   #12
Cam1968rsss
I do have a set up that has a 6 inch rod. With crank and pistons that came in the same kit. What is so confusing about that?
Old 05-27-2018, 08:40 AM   #13
b454rat
BIG difference in 6" stroke vs 6" rods....6" stroke is big for a big block.
Old 05-27-2018, 08:55 AM   #14
geezer#99
geezer#99's Avatar
Like this.
http://www.hotrod.com/articles/1211s...-block-engine/
Old 05-29-2018, 05:32 PM   #15
Tom
Tom's Avatar
Because you said 6" stroke. A 4.125 bore with a 6" stroke would be a 641cid engine, or 10.5L
You also said it was done instead of 5.7", but those didn't come in the engine from the factory.
Do you see where the confusion comes from yet?
Old 05-29-2018, 06:00 PM   #16
YoungPup1977
what size carb would he run on his 10.5L engine ?
YoungPup1977 is offline   Reply With Quote
Old 05-29-2018, 06:34 PM   #17
DieselSJ
Cam1968rsss
What is the duration on the cam? That makes more of a difference than the lift.
But from what you have told us so far, go with the 650.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 05-29-2018, 07:10 PM   #18
YoungPup1977
Comp Cam's has a 12-326 cam that yields a .490 lift with .286 duration with a power range from 2200 to 6200....with the two carbs of choice, most likely will not be the issue here.... degree the camshaft correctly and upgrade to 2500 rpm stall converter, just my 2 cents
Old 06-07-2018, 07:58 PM   #19
swissarmychainsaw
Cam1968rsss
I would contact Holley directly, they'll give you sound advice.
swissarmychainsaw is offline   Reply With Quote
Old 06-08-2018, 12:03 AM   #20
Captainfab
60-66 Nut
You can always use Holley's online carb size selector.
https://www.holley.com/products/fuel...s/carburetors/
