Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 10-29-2018, 02:40 PM   #1
RedBed
RedBed's Avatar
Pre-Paint prep questions
Wondering what I should use for wipe down pre-primer and pre-paint on my truck. I am using a lacquer based primer and shooting it with JD Blitz Black.
I can buy cleaner/degreaser at the local auto supply, but I also have plenty of Acetone, Alcohol or Lacquer thinner on hand.
Also what are the best wipes to use? Microfiber towels? Blue "shop towels"? ?
1979 Chevrolet Bonanza/305/4L60/Edelbrock Performer/Holley 600 Classic
RedBed is offline   Reply With Quote
Old 10-29-2018, 03:48 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Pre-Paint prep questions
i use wax and degreaser on mine
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-29-2018, 10:29 PM   #3
MP&C
MP&C's Avatar
A wax and grease remover is a slow to evaporate solvent, working on the premise that any impurities will be floated to the surface where they can be wiped away before the solvent dries. Think wax on, wax off. One lint free rag to apply, another to wipe clean. Lacquer thinner and the like are too hot, and tend to either dry before the impurities can be wiped away, or will soften your lacquer primer to help the impurities flow into the primer. Which brings up the next point, Lacquer primers are so 40 years ago. They are prone to adhesion delamination, softening (reflowing), and shrinking. Quite a few better choices out there.
Robert
MP&C is offline   Reply With Quote
Old 10-29-2018, 10:34 PM   #4
RedBed
RedBed's Avatar
Ok - I'll get the degreaser. Thanks!
I know Lacquer primer is not what most would use anymore, but neither is John Deere tractor paint. But that part is already done deal.
Old 10-29-2018, 11:28 PM   #5
Foot Stomper
Foot Stomper's Avatar
No need for a wax and grease remover if you haven't applied wax or grease... seriously, if you've primed a clean and dry surface, then sanded to a paint ready substrate, then blow it off and use a tack rag sold in the same store you buy the primer and paint, then paint.
If you are in a very dusty shop, or want to be extra careful, then a mild wax and grease solvent will help to clean the substrate with a micro fibre cloth or premium towel prior to using a tack rag.
The tack rag is the key here, don't use paper towel or other "lint" type products before paint... always use a tack rag. They are designed to grab every bit of dust and debris from the substrate. They cost 2.00$.
EDIT: Be very careful when using any wax and greaser, acetone, alcohol and/or lacquer thinner on lacquer primer as it will likely melt and wash off the primer because the modern day wax and grease removers are a hotter solvent and will literally disolve the lacquer. Best to just use a tack rag.
Question... what are you planning on using for paint??? Lacquer paint is hard (if not impossible) to find so you may end up with an acrylic enamel or urethane which will attack the lacquer primer and cause "crazing" if you don't know what you are doing. Lacquer primer went the way of the dinasour 40 years ago... I wouldn't use it on my wheel barrel... if it's not too late, I'd wash it off with lacquer thinner or sand paper and start over with a urehthane high build primer and have a far superior substrate that can be painted with a single stage urethane, acrylic enamel or base coat/clear coat.
Lacquer primer is a problem waiting to happen... there's no such thing as good, cheap paint. Why spend countless hours on metal work, body filler and then mess it up with lacquer primer?? Makes no sense to me.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 10-30-2018, 11:55 AM   #6
RedBed
RedBed's Avatar
Originally Posted by Foot Stomper View Post
...what are you planning on using for paint??? ...
My first post: "shooting it with JD Blitz Black"
Old 11-13-2018, 05:49 PM   #7
RedBed
RedBed's Avatar
Done!
http://67-72chevytrucks.com/vboard/s...d.php?t=775149
Old 11-13-2018, 06:39 PM   #8
mongocanfly
That turned out great..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-22-2018, 11:35 AM   #9
mikelom
Originally Posted by RedBed View Post
Nice work! Black and red are a good combination. Like it!
mikelom is offline   Reply With Quote
Old 11-26-2018, 07:59 PM   #10
Sparky dave
Need to clean the panel before the tac rag. Wipe across panel once then turn the cloth don’t rub back and forth or you will spread the dirt around. Clean clean and more clean with panel wipe until no more dirt comes off the panel. Thinners will wipe the primer off, stick with panel wipe. Tac rag is just for final stage just before you shoot ��. Wipe gentle with tac rag or you will leave sticky residue on panel. Most inportant don’t be scared all that can happen is you learn something. Go for it! Good luck
Sparky dave is offline   Reply With Quote
Old 11-26-2018, 08:02 PM   #11
Sparky dave
Ps the towels ideally you need to be looking for lint free cloths. If even used **** roll but I’m not telling you to do that!
