Old 04-10-2012, 01:33 PM   #1
67olds
annoyed
2006 chevy silverado 1500 non hd ccsb 4x4 5.3....i think i got it all.
My truck makes some annoying noises when i drive. Will sqeak at low speeds kinda like a brake sqeak but will stop as soon as i hit the breaks, then when im making left turns at low speed it sounds like the front left wheel is chirping?? for lack of a better way to describe it. Any ideas?
67olds is offline   Reply With Quote
Old 04-10-2012, 01:39 PM   #2
67olds
Re: annoyed
http://www.67-72chevytrucks.com/vboa...d.php?t=517862
Just noticed this thread, would that apply to my truck?
Old 04-10-2012, 05:56 PM   #3
truckdude239
truckdude239's Avatar
Re: annoyed
it could, for the brake noise check you brake pads most likey your pads are getting low and it is the squealers hitting and making the lose speed noise which goes away when hitting teh brakes. As for turning it could be a bad cv axle if it is 4x4 or a bad wheel bearing
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 04-10-2012, 10:23 PM   #4
HTX86chevy
HTX86chevy's Avatar
Re: annoyed
I would check wheel bearings asap.
HTX86chevy is offline   Reply With Quote
Old 04-10-2012, 10:37 PM   #5
71swb4x4
71swb4x4's Avatar
Re: annoyed
Check your u-joints. Applying the brakes puts enough pressure on the offending u-joint to stop the squeak.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-12-2012, 10:23 AM   #6
67olds
Re: annoyed
thanks
