06-27-2018, 07:09 PM | #1 |
20' Daredevil (Ret)
I/R Thermometers
Are the cheap ones any good? Are they all pretty much the same? Looking at several low-end ones more or less in the $15-$25 range. Mainly just want something to check the radiator for hotter / cooler areas to make sure it's flowing OK and no plugged tubes. Thanks, guys.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
06-27-2018, 07:14 PM | #2 |
Proprietor of Dale's Corner
Re: I/R Thermometers
I heard the harbor freight ones work pretty good. Even if it's a bit off it'll show temp differences.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
06-27-2018, 07:55 PM | #3 |
20' Daredevil (Ret)
Thanks Dale. Yeah, accuracy isn't that critical for my intended use. As long as it works and doesn't break right away.
I just got a new HF flyer with a coupon for $20. Might have to get one next time I go to town.
06-27-2018, 09:49 PM | #4 |
I just got my flyer too. I try not to look at them or I'll want something. ...lol
06-27-2018, 11:39 PM | #5 |
Mine is General brand and it seems to work pretty well. For all I know they might be made in the same factory in China as the HF models.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
06-28-2018, 06:13 AM | #6 |
Old member
My harbor freight one has worked well for over a year. I took it to work and compared it to a H/D calibrated one and it was only off by 1 degree.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
