Old 12-17-2017, 07:54 PM   #1
Slammed1964
64 bench seat adjusting cable
Does anyone know who sells the springs and cable used for adjusting a stock bench seat? I know classic parts carries the spring on the drivers side. Can not locate a cable that runs from driver to passenger side
Slammed1964 is offline   Reply With Quote
Old 12-17-2017, 09:25 PM   #2
PGSigns
PGSigns's Avatar
Re: 64 bench seat adjusting cable
It is not a cable its a solid rod. You will need to find one from a seat they are reproduced that I know of.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-17-2017, 09:36 PM   #3
Slammed1964
Ok thank you. Not sure mine is the original 64 seat. The adjusting knob is black. The ones for that year I see in parts catalogs are bare metal. I found a replacement cable thru LMC truck. Do you know if there are pics on underneath a correct seat as a guide to go by?
Old 12-18-2017, 10:39 PM   #4
rvrfoot
Mine broke i tied a wire to it. Not the right way but it worked.
rvrfoot is offline   Reply With Quote
Old 12-19-2017, 07:36 AM   #5
PGSigns
PGSigns's Avatar
You may want to post a picture of the seat and how it was mounted. That may help identify the seat you have. Once we figure out the seat you have finding the parts it is missing will be easier.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 12-19-2017, 11:16 AM   #6
63burban
Chevy addict
Sounds like you have a 67-72 seat. If you don't need original a wire works fine.
63burban is offline   Reply With Quote
Old 12-19-2017, 11:24 PM   #7
MusicMan70
MusicMan70's Avatar
I trimmed the longest section from a tomato cage to replace that rod.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 12-21-2017, 10:18 AM   #8
Rich 5150 69
Rich 5150 69's Avatar
Ingenious, would have never thought of that.....!
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
