05-20-2012, 02:38 PM | #1 |
Straight 6 250 sputtering after key is off
I have a 84 c10 with a 250 inline 6. Single barel carb. After truck is warm I shut the key off and the truck continues to sputter/pop for another 5-10 secconds. Anyone know what might be going on?? Thanks,Be njn
Posted via Mobile Device |
05-20-2012, 04:57 PM | #2 |
Re: Straight 6 250 sputtering after key is off
Its usually caused by the idle speed to fast. Also can be from a vacuum leak. Some of those used a selinoid on the throttle to drop it back when you shut it down.
05-20-2012, 10:40 PM | #3 |
Active Member
After you check what Wrenchbender said also check the timing and choke adjustment.
If all checks ok, get a couple of cans of good gas treatment to put in the gas tank. You may have a build up of carbon in the heads and it may take 2-3 tanks full with additive added to clean out. Took me about three tries but haven't had a recurrence since. |
05-20-2012, 11:47 PM | #4 |
Has the truck always done this?
Or is this a new problem in recent weeks? Is it a new problem after installing an elecric fan, radio....? |
05-21-2012, 04:00 PM | #5 |
Recently. The head is rebuilt and it may be a timing issue as a result of truck being slammed off a curb due to a near missed car accident. Maybe distributor spun alittle.
