03-20-2017, 09:23 AM | #1 |
AWD trans
Did GM or BOP ever provide a production all wheel drive trans with the standard 90 degree bell housing?
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
03-20-2017, 11:55 AM | #2 |
Re: AWD trans
Transmission would not be the "AWD" component. You want to look for an "AWD" transfer case.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
03-20-2017, 12:30 PM | #3 |
Re: AWD trans
ok then i'd still be stuck with a two component set up and even if the t-case was a 1 speed all wheel drive unit im still stuck with t-case of typical physical size?
03-20-2017, 12:34 PM | #4 |
Re: AWD trans
Yep. Look for a Syclone...that was a factory hot-rodded S-10 sized truck that was AWD.
https://en.wikipedia.org/wiki/GMC_Syclone Something like a BW 4473 would bolt to the back of a GM 4x4 transmission.
03-20-2017, 12:43 PM | #5 |
Re: AWD trans
interesting. thanks for your insight.
I have an option to build either a mid 80's Caprice Classic or a Town & Country station wagon where im looking to convert one of them into an all wheel drive ifs/irs with a little more clearance over stock and run a modest LS but i dont want to do a typical body onto 4x4 chassis swap. Just doing some homework for now.
03-20-2017, 08:01 PM | #6 |
Re: AWD trans
The 1 speed full time AWD Borg Warner 4481 from GMT-800 Cadillac Ecalades can easily take 500 ft lbs, No electronics & light weight., Splits the torque 40% front, 60% rear at all times.
The 1 speed full time AWD New Process 149 from a GMT-800 Silverado SS can handle 400-450 ft lbs, No electronic, Little heavier than the BW4481, "Normally" Splits the torque 38% front, 62% rear, But can apply 100% torque to the front or rear wheels via a "Viscous Coupler" The BW4481 works better with "stability control", Lets say the right front wheel losses traction, The stability control will apply the right front brake & applies engine torque to the left front wheel. Without stability control the front diff will act just like a open diff.....All 40% of torque will be applied to the spinning front wheel. The NP149 doesn't rely on stability control, The viscous coupler handles all the Torque Biasing, The more slip one axle has.....The more torque that is redirected to the other axle. |
03-20-2017, 09:43 PM | #7 |
Re: AWD trans
Thanks clinebarger, I appreciate the push in the right direction from both of you.
03-20-2017, 11:11 PM | #8 |
60-66 Nut
Re: AWD trans
I don't know what transfer case they use but the Express/Safari vans were available in AWD.
03-21-2017, 05:34 AM | #9 |
Re: AWD trans
03-21-2017, 05:48 AM | #10 |
Re: AWD trans
What was used in the AWD astro's.. and how much power can you throw at one..
03-21-2017, 08:24 AM | #11 |
Re: AWD trans
There's also the BW 4476 used in the Cadillac SRX wagons. No viscous clutch to burn out.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
03-21-2017, 09:30 AM | #12 |
Re: AWD trans
Thanks guys, ya i was doing a little reading last night and it looks like since the late 80's there is a couple of NVG and Borg Warner model single speed t-cases that offer awd in roughly that 65r/35f bias configuration. I was hoping to eliminate the need for the tcase since im looking to build a car which is not going to have the tunnel molding area for a t-case. Again, i dont want to turn this into a car body on 4x4 chassis but merely an awd car with front and rear independent suspension using an LS motor. I found some all wheel drive trannys but they are side ways mounted motors and nothing with the 90 degree bolt pattern.
I havent looked into the Caddy BW unit yet Bigdav, I'll check that out and find some pics of the underbody. Thanks.
03-21-2017, 09:52 AM | #13 |
Re: AWD trans
I don't know how you would get awd without a transfer case on a longitude mounted engine. Even high end Mercedes and bmw sport sedans use a transfer case.
The only car I can think of that has a longitude mounted engine and awd without a separate transfer case is the Subaru. But the engine is mounted in front of the front axle centerline, and it obviously wont bolt to a gm engine. |
03-21-2017, 10:01 AM | #14 |
Re: AWD trans
I see. Welp maybe it's not ment to be.
03-21-2017, 01:19 PM | #15 |
Re: AWD trans
There are also New Venture Gear transfer cases in Trailblazer/Envoys.
03-21-2017, 03:19 PM | #16 |
Re: AWD trans
I will have to do some measuring to see, but if the t-case landed roughly under the front seat that would allow for some floor contouring to keep it up tight with the body. I can make a clocking ring to rotate it flat but then I need to think about the front drive line. This is all why i was hoping there was such a thing as an all wheel drive trans for a longitude motor rather than going the tcase route.
03-21-2017, 03:57 PM | #17 |
Re: AWD trans
The engine oil pans on Envoy/Trailblazer/SSR have accommodation for the front axle passing through. I'm not sure the transfer case is much of issue.
I worked on an AWD G35 the other day. It uses a transfer case behind the transmission.
03-21-2017, 04:10 PM | #18 |
Re: AWD trans
i've seen some of those oil pans in certain apps. Pretty neat. How flat was the AWD G35? Did the body on this vehicle sit high off the frame to accommodate the drive train or was the the tunnel wide enough for the front driveshaft?
03-21-2017, 07:55 PM | #19 |
Re: AWD trans
I have an Envoy Denali with the 5.3 but they are 4wd and not AWD. I'm pretty certain that only the trailblazer SS with the 6.0 came in AWD.
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!! My Build Thread: Project 72' Green http://67-72chevytrucks.com/vboard/s...d.php?t=587932 |
03-22-2017, 12:07 AM | #20 |
Post Whore
Re: AWD trans
Im sure It was built with a unlimited budget but ken blocks mustang was 4wd....https://m.youtube.com/watch?v=RGvKjk_VrHE
03-22-2017, 12:47 AM | #21 |
60-66 Nut
Re: AWD trans
I don't remember what TC this guy used but there are a couple links in the comments to follow.
https://www.youtube.com/watch?v=Wtnvpgdfq9c
03-22-2017, 06:29 AM | #22 |
Re: AWD trans
Olds Bravada used the viscous coupling also. But yes, if you are using a GM drivetrain they are all trans + transfer case.
Suggestion - take one of the above units, make a block off plate and stub shaft set up for the front, and use it divorced. Allows you to place it where you want (within driveshaft limitations of course). Similar to a standard divorced transfer case.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
03-22-2017, 10:07 PM | #23 | |
Re: AWD trans
Neat stuff guys! I'll find the full build sheet on that Cutlass. I see he used a 4l80 trans but doesnt mention what t-case. Regardless, he must have clearanced the floor a lot. Not a big deal as long as that case lands under the seat where the custom floor pan can be raised without affecting foot wells for the case and front drive line. Regardless, I would run few inches taller than the Cutlass's stance which should help for drive train clearance. Read that he used the front and rear diffs out of a ZR2 S-10 truck and aftermarket shafts. So like some of you said, this is Typhoon and Cyclone drivetrain thus im betting the t-case too. Good call!
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's Last edited by snj8198; 03-22-2017 at 10:53 PM. |
03-24-2017, 01:50 AM | #24 |
Re: AWD trans
There are other vids of that cutlass where he goes into a little more detail about the drivetrain so search YouTube for "AWD Cutlass". I don't remember all of it but I believe the Bravada/S10 parts were the steering knuckles. Front diff may have been also but it could've been Trailblazer, pretty sure trailblazer was mentioned just forget what part it was.
03-24-2017, 10:07 AM | #25 |
Re: AWD trans
Thanks, will do!
