Old 10-08-2017, 09:19 PM   #1
cheepin
Rig pulling to right when braking
Our 87 V20 Suburban pulls to the right when braking. Pretty much everything is new. New all spring 4" lift,shocks,steering arm,brake calipers,pads,rotors,draglink and steering box. Tierod ends will be here tuesday. Was doing it before we put the calipers on. Thought that would solve it. Maybe the brakeline is clogged?
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
Old 10-08-2017, 10:34 PM   #2
mongocanfly
Re: Rig pulling to right when braking
could be deteriorated rubber brake line..have you tried bleeding the brakes to check for fluid flow? ...could be bad caliper
mongocanfly is online now   Reply With Quote
Old 10-08-2017, 10:45 PM   #3
cheepin
Just put the calipers on today. Since it was doing it before that I would assume it's not the new caliper. But It could be the line. I was doing the pedal pumping while my son bled. The pedal did feel different then when we bled the other side.
Old 10-09-2017, 12:43 AM   #4
rwhit57
rwhit57's Avatar
Deteriorated brake line is probably correct. Change the hoses both sides bleed brakes and I'll bet problem solved.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 10-09-2017, 06:03 AM   #5
mongocanfly
I've also seen twisted rubber brakelines...rolling the caliper over without realizing it...a kink or twist will hinder fluid movement
Old 10-09-2017, 07:18 AM   #6
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
10 to 1 it is a bad rubber line, if one is bad, the rest are not far behind, change then all.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 10-09-2017, 11:55 AM   #7
Keith Seymore
Keith Seymore's Avatar
There is also a fundamental design characteristic that causes the K/V trucks to go to the right during braking: the fore/aft steering drag link is trying to be compressed by the front axle windup. Since it can't be compressed it physically inputs a RH turn into the knuckle or, conversely, can also roll the steering wheel to the left. This is common on Blazers (shorter wheelbase makes them less stable and makes the phenomenon more obvious) and with 2 leaf front springs. Adding 3 leaf front springs (or a traction bar) to minimize axle windup helps the situation.
If you exhaust all of your brake options I would look at that next.
K
Chevrolet Flint Assembly
1979-1986
1986 - Present
Old 10-09-2017, 05:47 PM   #8
rwhit57
rwhit57's Avatar
K
I've never heard of this before. I've owned a couple of K trucks and never experienced it, or maybe just don't recall it. It seems you would have to be on the brakes pretty hard to get that movement, it doesn't seem possible under just normal braking unless the leaf springs were just that soft. I would think that lifting the truck would enhance that action though.
Randy
Old 10-09-2017, 06:33 PM   #9
Bandit130
Bandit130's Avatar
I experienced similar braking on 72 C10 I purchased in 2014. Searched and found that flex (rubber) brake hoses fail internally. They actually close up internally over time not allowing proper fluid flow to defective side. It pulled very hard right, so left side was bad. Replaced both. Same thing happened on the 74 C10 purchased in 2015. PO had replaced left but not right. Had slight pull to left. Replaced right side. worked great, no more pull.
This may not be your problem. Wanted to pass on my experience.
1974 Cheyenne 10 LWB 350/TH350/With AC
Bandit130 is offline   Reply With Quote
Old 10-09-2017, 06:43 PM   #10
Leonard60
Had the same issue on a new 1986 truck I bought in 86. Pulled to the right took it back to dealer got it back pulled hard to the left now truck was worse. They had it back in shop a few time finally they replaced every braking component on the truck (less the steel lines ) and that finally fixed it. After a couple of years the truck started to have real bad break fade never did figure that out so I traded it off. Bought a 1989.
Leonard60 is offline   Reply With Quote
Old 10-09-2017, 10:50 PM   #11
cheepin
So we seemed to have fixed the problem for the most part. Still pulls a little but not bad. But we have been chasing loose steering. Like I said it has about new everything. But the lift has only been on about a 2 months. Well finally figured out the front driverside ubolts loosened and let the spring center pin loosen. SO the axle was moving back and forth about 2"! Tightened everything down and it is fine now. The rig belongs to my son and I told him to re torque everything after a couple weeks of driving it 100miles a day to work. Well he didn't. Doah.
Old 10-11-2017, 10:28 AM   #12
Keith Seymore
Randy
It's inherent in the design. I used to make a living fixing trucks the dealership couldn't figure out.
Often once the customer is sensitized you have to have a "total kill" (and then some) for them to be happy.
K
1979-1986
1986 - Present
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
