Old 10-11-2017, 03:03 PM   #1
Mattchu60
Turn Signal not working on front right side
I am experiencing a problem that I do not know how to solve or where to start checking things.
Here is what happens - when i engage my turn signal for the right hand side the dash blinker does not blink, and the front blinkers do not blink - although the tail light DOES blink.
The left hand side works fine. Also if I try the hazards then I get just the 3 corners and no right front.
If I push really hard up on the stalk, sometimes I can get the front right to work and the dash light also comes on.
Any ideas of what is going on?
Mattchu60 is offline   Reply With Quote
Old 10-11-2017, 08:16 PM   #2
Mtblack412
Re: Turn Signal not working on front right side
Sounds like a bad stalk. If you push on it and it works then start there. Check the wiring at the light as well just to make sure that it isn't grounding out or shorted to something else.
Mtblack412 is offline   Reply With Quote
Old 10-14-2017, 07:03 PM   #3
mMad Dawg
You could also check the bulb.You may have a broken filament that is dropped down on the other one. Been there done that.
mMad Dawg is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
