Old 07-26-2017, 03:39 PM   #1
jabos
Rear brakes on a 51 3600
Where can I get rear brake shoes and wheel cylinders for my 3600? I have tried classic parts and LMC no luck. Thanks for any input
jabos is offline   Reply With Quote
Old 07-26-2017, 04:18 PM   #2
Wrenchbender Ret
Re: Rear brakes on a 51 3600
Jim Carters handles parts for the Huck brakes.
Wrenchbender Ret is offline   Reply With Quote
Old 07-26-2017, 07:07 PM   #3
jabos
Thanks, I checked and they do have the wheel cylinders but no shoes.
Old 07-26-2017, 07:23 PM   #4
MIKESAD50
Have you looked around to have your shoes relined?
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 07-31-2017, 07:47 AM   #5
jabos
Thanks,I did find somebody to reline the shoes for me. I dont understand why you can't get new rear shoes but you can on the front ones.
Old 07-31-2017, 01:13 PM   #6
MARTINSR
MARTINSR's Avatar
It's probably because the fronts have more applications than the rear, maybe more years or something like that.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 07-31-2017, 08:36 PM   #7
dwcsr
Hollister Road Co.
dwcsr's Avatar
The fronts fit more trucks 3100, 3600, some 3800 fronts 1-3/4". The HD rears are usually 12 x 2 or 14"x2.5" and only fit trucks 3600 and 3800 rear for a narrow band of years. Its very common for larger shoes to be relined only. I suspect it also comes down to available cores to reline.
Old 08-03-2017, 05:44 PM   #8
jabos
I got the shoes reclined and now I cant get the drums on. They will go if I hammer them on but that seems to be to tight
Old 08-03-2017, 06:20 PM   #9
dwcsr
Hollister Road Co.
dwcsr's Avatar
from what I remember of relining shoes back on the 60's we had to shape the relines on a shoe grinder so they would fit the drum arc. You may need to bring the shoes and drums to the re-liner for then to shape the shoes
Old 08-03-2017, 09:01 PM   #10
1project2many
Yep, called "contour grinding." Find a big truck shop that relines brakes. They can usually do it.
1project2many is offline   Reply With Quote
Old 08-06-2017, 08:05 PM   #11
jabos
Thanks guys I will look into that.
