Old 09-30-2011, 10:32 PM   #1
7111127
6 lug to 5 lug
i got a 1970 gmc with 6 lug drum what is the cheapest way to get it 2 5 lug maybe with disc brake this rear axle i got a front end for it alrdy with disc on 5 lug
7111127 is offline   Reply With Quote
Old 09-30-2011, 10:35 PM   #2
77chris03
77chris03's Avatar
Re: 6 lug to 5 lug
71-72 spindles or order aftermarket
68 C10 Stepper #1- GONE 68 C10 Stepper #2
1977 Chevy Cheyenne...gone...was my first Chevy
04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD
99 Sierra Stepside, 17 Denali HD, 84 K10
My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333
My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310
77chris03 is offline   Reply With Quote
Old 09-30-2011, 11:05 PM   #3
SCOTI
SCOTI's Avatar
Re: 6 lug to 5 lug
Cheapest way is to swap disc brakes from a 71-87 over. You get the 5x5 pattern & it's a direct swap using junkyard parts if desired.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-30-2011, 11:56 PM   #4
7111127
Re: 6 lug to 5 lug
for the rear yes? i alrdy got parts for the front just gotta put em on
edit: can i take the guts from a 96 impala axle and put them in this one?
Old 10-01-2011, 09:55 PM   #5
Robznob11
Robznob11's Avatar
Re: 6 lug to 5 lug
I ordered my axles from moser for 300 they are non tapered and 40% stronger. while I was at it I ordered mine with the 5 on 4 3/4 car bolt pattern because you can get wide wheels like drag lights for that bolt pattern. also you can find a lot of used car wheels but truck wheels not so much unless you are going with new style 20s or something. I bought a set of 11x2 rear drums for a late 60 muscle car don't remeber the model but the napa # ended in 1060. I had to enlarge the 7/16 holes to 1/2 because I also opted for 1/2 screw in racing studs. I did this because I wanted the widest tires possible on the back with out narrowing the rear. You can get car wheels 12 wide with a 7.5 bs wich will allow you to stuff a 18.5 mt under there if you want. I know this is not what you are asking but you will have more than 300 in a different rear by the time you swap it and moser will give you a part much stronger and will slip right in. Im happy I went that route. not to mention after reasearching my 68 axle is nearly as narrow as any of the car axles. and there was no welding involved. just my .02 if you go with the truck bolt pattern you can use 71-72 rear drums. they already have your measurements you just need to tell them your lug options
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 10-02-2011, 12:52 AM   #6
Captainfab
60-66 Nut
Re: 6 lug to 5 lug
No, that won't work. You can install the complete Impala rear end under your truck. You will have to do some cutting and welding though. It has been done, and I believe it is a bit narrower than the truck 12 bolt, if that is of interest to you.
If it's just the rear disc brakes you're after, I sell the brackets to mount the Impala disc brakes on your truck 12 bolt. But you would still need the conversion axles. Those can be found at ECE, CPP, and Summit.
Old 10-05-2011, 03:09 PM   #7
7111127
Re: 6 lug to 5 lug
how much shorter? inch?
