10-04-2017, 03:58 PM | #1 |
Spongy Brakes 95 1500
I just picked up a 95 1/2 Ton Silverado. ABS light is on, and the brakes are spongy. It stops fine, and on the drive home when I stabbed them, the rears momentary locked up, I let off the pedal and the brakes released. The BRAKE light come on once in awhile but only for about 45 seconds or so. Full of fluid. Where should I start looking? Thanks
10-05-2017, 06:26 PM | #2 |
driving is in my blood
Re: Spongy Brakes 95 1500
Master cylinder.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
10-07-2017, 11:03 AM | #3 |
if your new to these kinda trucks the brakes were always kinda spongy on them. my 1990 had everything replaced a few years back and you still dont ever get a perfect brake pedal, same with all the ones i ever worked on.
but hard to tell if you have other issues, poorly adjusted rear drums, bad master, air in system etc |
10-07-2017, 04:39 PM | #4 | |
10-07-2017, 08:52 PM | #5 |
Wheel is wet of the brake drum is wet? If the drum is wet, you probably have a leaking wheel cylinder and need to replace it ASAP.
10-07-2017, 09:04 PM | #6 | |
Both. Yeah, I know it needs serious attention. I'm not driving it anymore. Just didn't have time today. Hopefully that is the only issue that is causing the spongy brakes. |
